Boot Slide mod. No more blowing cv boots.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 802YOTA, Mar 16, 2011.
  1. Dec 6, 2015 at 11:14 AM
    #141
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Using the all rubber SDHQ 930/934 style boots and clamping them on the larger opening with the standard clamps supplied while running a regular size zip tie then clamping it down tightly on the smaller end of the boots usually keeps the boots happy enough to where they can slide up and down the shaft, yet still provide a very minute/ minimal amount of grease from getting out.
    Speaking from personal experience here.
    I don't like the boot slide mod. Especially on stock style boots.
  2. Dec 7, 2015 at 8:24 PM
    #142
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    So I got new OEM CV remans and also the SDHQ outer boots and those other longer inner boots (All Pro I think?).
    Anyway I'm trying to decide if I should change the boots out now or hang onto the boots until something tears. I got the grease and its just the work of disassembling a new CV and swapping out the boots.
  3. Dec 8, 2015 at 11:09 AM
    #143
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Close, the boot goes on the shaft first then the cut off small end of the old boot and c-clip gets placed in the groove where the boot originally sat and 3/8" not 3/4" slide is all that's needed.;) Gluing the boot is ancient history.
    I originally created and further developed the process, I didn't name it or start this thread.
    There is no significant advantage to manual hubs in terms of fuel savings or reduced wear. In fact the manual hub CV shafts are not as strong as ADD shafts. The strength difference is negligible, the issue is how the shaft fails. The weakest point of a man hub shaft is inside the hub assembly so consequently if a shaft failure (not the CV joint) happens there it takes out the expensive hub with it $$$. Further, the vacuum actuated ADD diff combined with a manual shift transfer case is extremely reliable. Far more so than the later all electric systems.
    Larger boots? Yep, around 16 years ago Kartek started marketing Porsche 930 CV boots as "high angle" boots for the Tacoma. They were/are problematic from the get go because the OEM inner CV housing or "bell" is triangular and the 930 boot is round. This requires the big end of an old OEM boot to be cut off and left in place to fill the voids. The 930 boot is clamped on top of this old boot part. The old boot portion has a groove for the clamp and is not flat so you are clamping two irregular surfaces together. This set up was/is known for seeping grease and flat out popping clean off the old boot piece. Along with the "fit" problems I had one torn by brush (thinner material). The 930 boots hold a good bit more lube than stock so this makes about as big a mess as you can have on a Taco. Straight from SDHQ "getting a 930 Bates style to work is kind of a PITA". SDHQ also does sell aftermarket stock replacement inner boots for 1st gens. They are dimensionally identical to OEM, both are neoprene and OEM is thicker. They are made by Empi and have been sold thru many parts houses as service replacements for years. They are not "high angle" boots. Again straight from SDHQ "If you rub with OEM boots you will rub with ours".
    I tried the 930's many years ago and developed the several BS methods as an alternative that also happens to be free.
    Your call there but I would run them as is, at least for a while (they're paid for). Just keep an eye on the inner boot ribs. If they are going to rub thru you should see it in plenty of time to change them out at a convenient time/place. OEM outer boots are made of a harder material then the inners. This is where the hype about "stiff plastic" OEM boots comes from. In the real world, outer boots (due to shape) do not suffer as much from lifting and failure is rare compared to the inners. There are folks out there running extreme ride heights that will cause outers to rub, among a host of other problems.
    "Slid" OEM boot looks nearly new after 200K lifted miles.
    Original test bed shaft as a spare, stored behind rear bumper and mummified for posterity.
  4. Dec 16, 2015 at 1:49 PM
    #144
    cynicalrider
    cynicalrider #NFG
    Jersey
    Hey @Dirty Pool I bought the SDHQ boots, these to be exact and since it does not come with a replacement C clamp, where would you recommend I source one for the mod? Do you know the size so I can just get it from a parts store? Or just get an assorted dorman kit? Thanks.
  5. Dec 17, 2015 at 10:15 AM
    #145
    Dirty Pool
    99 XCAB V6 MT TRD
    The I.D. of the OEM c-clip is 1 inch.
    A plane old 1" I.D. "external" retaining ring as seen in the bottom of the pic below should due fine. It does not need to be a perfect fit, just not loose. When you cut the old boot shoot for around 3/8". More is not better.
    The OEM band clamp for the big end of the inner boot is reusable so you can start your collection.
  6. Dec 17, 2015 at 10:38 AM
    #146
    cynicalrider
    cynicalrider #NFG
    Jersey
    Awesome, thank you!
  7. Dec 24, 2015 at 1:11 PM
    #147
    jaunty
    jaunty Well-Known Member
    99 V6 TRD Automatic 4x4
    Thanks for the knowledge. I'd have to disagree here about reduced wear though. I rarely use 4WD. If my axles weren't spinning on the road then certainly the boots wouldn't be split open right now. A manual un-locking hub would not allow the shaft/boot to spin and wear out as fast.
  8. Jan 20, 2016 at 12:55 PM
    #148
    tacotecno
    tacotecno New Member
    Canada
    2002 4x4 double cab tacoma
    None
    Seems to me i am not the only one who's confused here !!!:eek::rolleyes::help:
  9. Jan 21, 2016 at 4:13 AM
    #149
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Which part is confusing you?
  10. Mar 1, 2016 at 10:41 AM
    #150
    WestsacTRD
    WestsacTRD Member
    How do you Get C clip around Axle?
    tacomatrd22 likes this.
  11. Mar 1, 2016 at 11:17 AM
    #151
    cynicalrider
    cynicalrider #NFG
    Jersey
    Snap ring pliers and a whole lot of swearing worked for me. Though getting it off was the harder part.
    ThunderOne likes this.
  12. Mar 1, 2016 at 12:02 PM
    #152
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Getting it off was definitely the harder part. It was a struggle to get on for me also. But I eventually found a quick way. I took pole from my jack which happens to fit around the axle perfectly and the same diameter of the snap ring. Spread the snap ring and then one quick bump with the jack handle it went straight down.
  13. Mar 1, 2016 at 12:08 PM
    #153
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    hmmm, subbed
  14. Mar 2, 2016 at 12:19 AM
    #154
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    I'm about to replace my CV boot since the lift kind of killed it.
    But just in case I cut and use the end of the old inner CV (the flange if I remember right) and use the OEM band (that's inside the inner boot?) and use that to keep the flange in place?
  15. Mar 2, 2016 at 8:12 AM
    #155
    chowwwww
    Orange County
    03 Doublecab 4x4
    You use the inner band of the boot. Once you take the axle apart, you will see a beefy snap ring. Reuse that snap ring to hold the old inner boot in place.
  16. Mar 2, 2016 at 8:35 PM
    #156
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Alright that makes more sense thanks!
  17. Mar 10, 2016 at 5:27 PM
    #157
    Blackouts
    Blackouts Well-Known Member
    Las Vegas, NV
    2014 Tacoma TRD Off Road DCSB
    Looks interesting, I might have to try this.
  18. Mar 10, 2016 at 7:37 PM
    #158
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Well I took out my CV out and got the wrong boot but I saw the beefy snap ring and moved it towards the bottom but doesn't moving that snap ring (C-clamp) have any effect with how the needle bearings sit?
  19. Mar 11, 2016 at 5:54 AM
    #159
    cynicalrider
    cynicalrider #NFG
    Jersey
    You need an additional snap ring/c clip. The one c clip will hold the boot in place and the other goes in the original location. If you got an OEM reboot kit you will have new c-clips in the kit. If not you will need to source a new clip. I was able to use a 1" inner diameter snap ring to hold the boot and the c-clip stayed in it's original position since I did it with the DSM boot kit that does not come with new c-clips.
  20. Mar 11, 2016 at 7:25 AM
    #160
    chowwwww
    Orange County
    03 Doublecab 4x4
    The C-clip should be going all the way over that bump. It should sit in the groove after that bump. Also, in that bump should be the left over cut out inner clamp part of the original ripped boot cut roughly 3/8". When I assembled mine. This is the order I put it back together: New boot goes on first, then the cut part of the original boot, then the C-clip. The cut part of the boot is what helps slide the new boot down and keeps it there. Also makes it harder for grease to pass and leak out. See below at dirty pool's pic.
    Dcsleeper408 likes this.
