Boot Slide mod. No more blowing cv boots.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 802YOTA, Mar 16, 2011.
  1. Mar 11, 2016 at 7:28 AM
    #161
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
  2. May 15, 2016 at 11:09 PM
    #162
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    Anyone know the part number for the c clip used to do this? I've now been given three differentry part numbers from toyota ando ordered 6 incorrect c clips.
    I'm trying to do the method with the 3/8 peice of the old boot and one c clip.
  3. May 16, 2016 at 6:32 AM
    #163
    cynicalrider
    cynicalrider #NFG
    Jersey
    I used a 1" inner diameter snap ring. Could also just get a whole boot kit and get the clip from there and have spare parts.
  4. May 16, 2016 at 11:31 AM
    #164
    552Jrider
    Jeremy
    Norcal
    2002 DC 4x4
    I know can use a snap ring. They are just kinda thin and flimsy. Was trying to get one of the actual cost clips without buying about damn boot kit.
  5. May 16, 2016 at 11:44 AM
    #165
    cynicalrider
    cynicalrider #NFG
    Jersey
  6. Sep 29, 2016 at 3:45 AM
    #166
    Dan_meister
    Dan_meister Member
    Daniel
    Pueblo, Co
    99 Tacoma Sr5 3.4L
    Lift, Tires.
    I thought the problem was because of the angle with lifted trucks and only affecting the outter boot? That's what blew on mine anyway. I have an ugly angle on mine with just toytecs 3 inch lift. I've only blown one since 07 when I put the lift on but very little wheeling to this point. That's about to change and I'm wondering what to do to alleviate this.
  7. Jun 17, 2017 at 8:45 AM
    #167
    tacopablo
    tacopablo Well-Known Member
    Québec
    2002 tacoma 2.7l
    ClevSix likes this.
  8. Oct 6, 2017 at 8:27 AM
    #168
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    I'll be rebuilding some CV's soon. Curious if anyone had tried clamping the cut off boot end with the lower profile CV band clamps instead of the having the two ears sticking out from the circlip? I've got a few of those sitting around from my previous days as a tech. I have access to the circlips also from the hardware stash at work if this is the preferred method.
  9. Oct 9, 2017 at 12:16 PM
    #169
    STLTacoma
    STLTacoma Well-Known Member
    St.Louis, MO
    I solved this issue.. bought lifetime warranty axles from Oreilly’s, just swap them out takes no time.
    CS_AR and aeok18109 like this.
  10. Oct 11, 2017 at 7:31 PM
    #170
    Buckaroo1993
    Buckaroo1993 Who?? ME??
    Vinny
    Georgia
    2003 3.4L BSP DCSB TRD OFF-ROAD/SR5 4WD
    17x9 HELO HE878 with Hankook RF10 DYNAPRO AT-M LT275/70R17 RCD/Billie's Front and Rear with OME 883's and HS Progressive AAL Resulting in 3"+ Lift LR SPC UCA'S Diff Drop K&N Cold Air Intake LED's Exterior/Interior
    Can this be done without removing the entire axle? Can the outer end of the inner boot be unclamped, pushed back toward the diff, slip the "C" ring in the groove and SOMEHOW get the rubber spacer/grommet in front of it and slide the outer in over all that and clamp it tight?
  11. Oct 13, 2017 at 8:27 AM
    #171
    clayshutr
    clayshutr Well-Known Member
    Robby
    Central MO
    02 dc 4x4, 08 T4R v8
    ome 882 billy's dakars 255-80-17 STMAXX SCS F5 some other random doodads
    in short no..... It takes an extra 30 seconds to pull the axle out and it will save you so much time and headache to do it out of the truck
  12. Oct 13, 2017 at 8:37 AM
    #172
    Buckaroo1993
    Vinny
    Georgia
    30 seconds?!?!
  13. Oct 13, 2017 at 8:40 AM
    #173
    clayshutr
    Robby
    Central MO
    If you have the axle torn down enough to do this mod, it takes an extra 30 seconds to pop it out of the front diff.
    I can have one out and rebuilt and back in the truck in about 45 minutes....
  14. Oct 13, 2017 at 8:47 AM
    #174
    Buckaroo1993
    Vinny
    Georgia
    Oh. I wasn’t planning on pulling it. That’s why I asked the question I did.
  15. Oct 13, 2017 at 8:53 AM
    #175
    clayshutr
    Robby
    Central MO
    If your gonna do this mod you have to separate from the knuckle and disassemble the outer joint. Why not take the extra 30 seconds and just remove the whole axle so you can work on the bench or tailgate or what ever. It would save so much time.
    Wulf likes this.
  16. Apr 12, 2018 at 4:09 PM
    #176
    kosherDILL
    kosherDILL Well-Known Member
    Andrew
    Pittsburg
    1998 Tacoma SR5 tan
    better power and ground cables in engine bay, on-board air compressor, complete OME suspension 883 coilovers and Dakar Leaves, Total Chaos UCA's, TRD Pro wheels, 265/70/17 tires
    Ok so all that I've read and understood refers to the inner boot. is there any reason i should worry about my outer boot? it seems like the fins could possibly be too close together. just recently put OME lift and diff drop on, have not received my UCA's in the mail yet. is this something that can be done to outer boots?
  17. Apr 17, 2018 at 11:50 AM
    #177
    clayshutr
    Robby
    Central MO
    No need, they will flex at the outer joint much more with suspension travel, where the inner is more constant angle. Touching is not an issue for them.
  18. Aug 3, 2018 at 4:59 AM
    #178
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Guess I’m gonna have to look into this mod. After installing my OME lift, both inner C.V. boots are spooging grease from the end. They aren’t torn at all, just leaking past the clamp at the end.
  19. Jan 13, 2019 at 9:11 AM
    #179
    Wunhunglo
    Wunhunglo Member
    02 crew trd
    3 in lift, 33's, and steelies
    New axels with lifetime warranty. 2months later the outer boot torn on right side. No wheeling or anything just normal driving. Is this somewhat normal (bad luck)
  20. Jan 13, 2019 at 9:27 AM
    #180
    eon_blue
    Azusa, CA
    Which axles? Places like Autozone and Pep Boys sell their own brands with life time warranties but they are much weaker/less quality than OEM. Only good thing about those is the lifetime warranty so you can replace them for free, but they don't tend to last very long. 2 months is really short but it happens, especially if you're lifted 3"
