Bora 1” spacers on stock TRD OR wheels, cutting studs?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mrandy77, Apr 21, 2022.
  1. Apr 21, 2022 at 11:16 AM
    mrandy77
    mrandy77 [OP] Member
    Upstate NY
    2022 TRD OR
    As the title says I want to run 1” Boras on stock TRD Offroad wheels. Do the stock studs need to be cut or not to clear the back of the wheel or do I need to go 1.25” to avoid cutting? Thanks.
  2. Apr 21, 2022 at 11:23 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    If your using stock wheels? No, for sure, even with 3/4" spacers. There is pockets between stud holes on wheels. If I remember correctly 1" spacers, studs are out past 1/8" or so.
  3. Apr 21, 2022 at 11:29 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I concur, for my 17-inch alum OEM wheels, when I had one inch adapters/spacers, the OEM lugs stuck out about half an inch and they fit nicely in the holes behind the wheels and between the stud holes.
