Bora spacer stud replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by stealthmode, Mar 26, 2022.
  1. Mar 26, 2022 at 10:12 AM
    stealthmode
    stealthmode [OP] Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Can you replace just the stud on Bora spacers? Or is it an entire spacer replacement if they are damaged? Had my truck in for free tire rotation and they showed me two studs at the end look like they are toast.
    Almost melted or extremely cross threaded (at the end of 2 studs)... will try to post pics if I can.
    :crazy:
  2. Mar 26, 2022 at 10:21 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Sounds like they did that for you. Guess they should be replaceable, pressed in.
    JJ Diablo and eurowner like this.
  3. Mar 26, 2022 at 10:26 AM
    stealthmode
    Alberta
    I was thinking they would be replaceable as well (pressed in), but not familiar with the construction of them so throwing out to TW folks. I'd hate to compromise the design.
  4. Mar 26, 2022 at 10:38 AM
    na8rboy
    WI
    Go to Bora site, send a message to them.
  5. Mar 26, 2022 at 10:42 AM
    stealthmode
    Alberta
    Good point. That's next I think.
  6. Mar 26, 2022 at 10:50 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I replaced a few of mine on the spidertrax ones I run. Some came out easy enough, another didn’t budge..
    na8rboy and stealthmode[OP] like this.
  7. Mar 28, 2022 at 1:39 PM
    stealthmode
    Alberta
    Update: I contacted BORA and they were willing to send out just studs, which tells me that replacing just the studs is feasible and safe. They also mentioned that air tools for installation AND removal are not recommended when doing tire rotations. 5/5 customer service and response times.
    The said shop attempted to replace the studs with same spec, but the length of the replacement studs were not quite the same length. Maybe 1/16 " of difference short, and as anyone who installs these 1.25" spacers know, thread count is at a bare minimum for the nut. So they are stepping up and ordering a new replacement unit for me.
    @Sterling_vH111
    @na8rboy
    Sterling_vH111 likes this.
