Bora Wheel Spacers Group Buy
Discussion in 'Automotive Group Buys' started by Captain Taco, Feb 6, 2017.
  1. Apr 9, 2017 at 10:30 AM
    #341
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Anyone wanna trade my .75 for your 1" or 1.25?
  2. Apr 10, 2017 at 6:05 AM
    #342
    tyme_and_place
    tyme_and_place Well-Known Member
    Justin
    2016 DCSB TRD OR 4x4 MGM w/all the fixin's
    Pm sent
  3. Apr 10, 2017 at 9:21 AM
    #343
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    .75" doesnt clear the bolt right and requires cutting?
  4. Apr 10, 2017 at 9:30 AM
    #344
    anthony250f
    Anthony
    San Diego, CA
    Not if you have the correct wheels...I still rub my resi
  5. Apr 10, 2017 at 10:02 AM
    #345
    pngo121
    Phi
    Pittsburg, CA
    Yeah my wheels are flat in back. Wouldn't work.
  6. Apr 11, 2017 at 9:18 AM
    #346
    Argo98
    Argo98 Well-Known Member
    Argo
    2017 Toyota Tacoma TRD-Sport 4x4
    Rough Country 3" spacer lift w/ shocks 285 KO2's wrapped around 16' ProComp Series 7069 Misc. bibbidybob lights
    What are the pros to adding spacers on a truck? I have a '17 TRD Sport 4X4, is there any off-road added benefits?
  7. Apr 11, 2017 at 9:27 AM
    #347
    pngo121
    Phi
    Pittsburg, CA
    mainly for looks. some use to clear uca to run bigger tires. i use them to clear my bbk.
    Captain Taco[OP] likes this.
  8. Apr 11, 2017 at 9:31 AM
    #348
    Argo98
    Argo
    Would I be able to run wider tires without rub or a lift kit? BBK?
  9. Apr 11, 2017 at 9:43 AM
    #349
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I first put spacer on for the better look. 265/75r16's on stock rims didn't rub, but they were tucked under the fenders and looks small. Extending them out 1" changed the entire perspective. Now that I'm running 285/75r16's on stock OR wheels, those same 1" spacers give me clearance at UCA's.
  10. Apr 11, 2017 at 10:16 AM
    #350
    Argo98
    Argo
    So will I be able to fit 285's on my TRD Sport wheels?
  11. Apr 11, 2017 at 10:17 AM
    #351
    Bluegrass Taco
    Bill
    Mt Washington Ky
    You SHOULD be able to.....
  12. Apr 11, 2017 at 10:26 AM
    #352
    Argo98
    Argo
    Would I get any rub when flexing the rig or off-roading? Also, would a leveling kits reduce the odds of rub?
    Edit: Do I only need spacers in the front? Square setup all around? Staggered?
  13. Apr 11, 2017 at 10:30 AM
    #353
    la0d0g
    running for the hills
    For crawling not hauling
    All trucks are different. Only by cycling the suspension on YOUR truck will you know where you scrub.
  14. Apr 11, 2017 at 10:32 AM
    #354
    Argo98
    Argo
    Sounds good, I drive a TRD Sport 4X4 with stock suspension and wheels/tires
  15. Apr 11, 2017 at 10:47 AM
    #355
    anthony250f
    Anthony
    San Diego, CA
    Spacers make rubbing worse on body mounts and fenders
  16. Apr 11, 2017 at 10:55 AM
    #356
    Argo98
    Argo
    I just went from semi-confident on getting 285's, back to shitting myself about rub.... So would spacers and a leveling kit alleviate the rub?
  17. Apr 11, 2017 at 10:59 AM
    #357
    la0d0g
    No, spacers are going to make it worse. Getting new wheels with the right amount of BS/offset for your application, paired with a lift or cutting will alleviate the rubbing.
  18. Apr 11, 2017 at 11:02 AM
    #358
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    Do yourself a favor and search cab mount chops if seriously considering 285's. It is a likely course of action when looking to run that size
  19. Apr 11, 2017 at 11:22 AM
    #359
    anthony250f
    Anthony
    San Diego, CA
    Wait you thought you could fit 285 with NO lift?
  20. Apr 11, 2017 at 11:40 AM
    #360
    The Taco Bear
    The Taco Bear Well-Known Member
    Franklin, Tennessee
    2018 4Runner TRD Off-Road
    2018 4Runner Off Road TRD SEMA Wheels TRD Skid Plate Prinsu Full Roof Rack RCI Skids Icon 2.5 ext front with resi Icon 2.0 ext rear T13 rear coils Camburg UCA RSG Sliders C4 LoPro 2011 Tacoma TX Pro — Sold Pelfreybilt hybrid bumper Icon 2.5 ext. Non Resi Icon 2.0 Rear with Resi Icon AAL Total Chaos UCAs CaliRaised LED Ditch Lights TRD Exhaust & Intake System TRD Fake Bead Lock Wheels BAMF Sliders Uniden Comm System w/ 4ft fire stick JBL Audio Future Mods: UBolt flip kit with bump stops. Dakars Skids Bed Rack
    I'll just place this here....https://www.tacomaworld.com/threads/tacoma-lift-faq-guide-read-this.11282/...... Read this should solve your answers.
    Edit: Cause you're probably gonna have to run a 3in with a CMC to run 285's unless you have proper Caster with your stock UCA's ( which you prolly don't cause you know they are stock) also the backspacking on your wheels. I know the stock OR don't have enough so a CMC is required.
