Bora Wheel Spacers Group Buy
Discussion in 'Automotive Group Buys' started by Captain Taco, Feb 6, 2017.
  1. Apr 20, 2017 at 10:13 AM
    #381
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Cut and re patch
  2. Apr 20, 2017 at 10:15 AM
    #382
    la0d0g
    running for the hills
    For crawling not hauling
    It's the frame not the body. Weld a plate on it and 99% of people will never notice :D
    Argo98[QUOTED] likes this.
  3. Apr 20, 2017 at 10:26 AM
    #383
    Argo98
    Argo98 Well-Known Member
    Argo
    2017 Toyota Tacoma TRD-Sport 4x4
    Rough Country 3" spacer lift w/ shocks 285 KO2's wrapped around 16' ProComp Series 7069 Misc. bibbidybob lights
    I'll think about it, I like the idea of it... Any shops or willing hands around the LA area who can help?
    Shmellmopwho likes this.
  4. Apr 20, 2017 at 10:29 AM
    #384
    anthony250f
    Anthony
    San Diego, CA
    @Shmellmopwho great price and great work!
  5. Apr 20, 2017 at 11:36 AM
    #385
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    $90 CMC whenever I have time lol
    Thanks buddy for the shoutout
    anthony250f[QUOTED] likes this.
  6. Apr 20, 2017 at 11:39 AM
    #386
    anthony250f
    Anthony
    San Diego, CA
    Anytime bro. Mines cut but I need it plated in. If it rubs offroad I'll hit you up.
    Shmellmopwho[QUOTED] likes this.
  7. Apr 20, 2017 at 11:51 AM
    #387
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    Sounds like a plan
  8. Aug 29, 2018 at 8:01 AM
    #388
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
    loctite or tight to OEM spec ?
  9. Aug 29, 2018 at 8:20 AM
    #389
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    Both
    ColoradoTJ likes this.
  10. Aug 29, 2018 at 8:27 AM
    #390
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    I have 1.5 bora in the rear, Hub centric to the oem hub and hub centric to my method rim. no loctite just tight to oem spec . Talked to Lenny and custom wheel offset they both said not to use loctite and lenny said the the loctite can eat the Zinc off the oem stubs and witch will make them rust
  11. Aug 29, 2018 at 9:01 AM
    #391
    pngo121
    Phi
    Pittsburg, CA
    Spidertrax provides loctite with theirs. So I guess it’s up to you.
    dillonk1602[QUOTED] likes this.
  12. Aug 29, 2018 at 9:15 AM
    #392
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    how do you like the 488 gears?
  13. Aug 29, 2018 at 9:16 AM
    #393
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I had Bora 1" spacers for almost 3 years. (77K miles) When I bought new wheels, I no longer needed them. In that 3 years, the spacers were on and off maybe 5 times (brake work, etc...) Wheels were off maybe 15 times (tire rotation, etc...) I never once used Loctite. Never once had a loose lug nut (Inner OR outer...) Unless you experience loose lug nuts WITHOUT spacers, there is no reason to believe you'll have issues WITH them. If the manufacturer suggest Loctite, by all means use it. Not my product liability insurance on the line. But nothing from my experience would indicate a NEED to do anything but properly tighten lugs and go on with life.
    YMMV.
    dillonk1602 likes this.
  14. Aug 29, 2018 at 9:18 AM
    #394
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Neither. Guttentite, that is my OEM torque spec.
    TireFire and dillonk1602[QUOTED] like this.
  15. Aug 29, 2018 at 9:26 AM
    #395
    la0d0g
    F that. Spec all day! :D
  16. Aug 29, 2018 at 9:39 AM
    #396
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Hang on, here's another zinger for you guys. I used an impact gun as well to torque the lug nuts down.
    ZOMG!!! :eek: His wheels are going to fall off on the freeway! :D
  17. Aug 29, 2018 at 9:41 AM
    #397
    la0d0g
    I'm not worried about the freeway. It's when I've been on dirt for 50+ miles that I don't want something to take a shit!
  18. Aug 29, 2018 at 10:30 AM
    #398
    12TRDTacoma
    Rob
    Concordia
    Boosted
    My wheels stayed on after hundreds of highly abusive off-road miles and thousands of miles in between tire rotations. Easily over 15,000. Not saying anyone has to follow my lead, but it is my very researched findings that my rig was safe. I think most people don't realize or forget that Toyota uses both a lug and hubcentric design in their wheels.
    If anything was going to take a shit on me during my time in the dirt it was going to be my suspension not my wheels due to failing wheel spacers or loose lug nut studs and I'm very confident in saying that. Lol.
  19. Aug 29, 2018 at 12:32 PM
    #399
    la0d0g
    All I'm saying was why overtighten lugs and possibly introduce another weak point when you don't have to.
  20. Aug 29, 2018 at 12:33 PM
    #400
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    This is why we can't have nice things and spacers get a bad rap. Torquing to a proper spec takes an extra couple minutes and you know without a shadow of a doubt it's correct.
