Borla #14945 Stainless Cat-Back Exhaust Sytem on an XtraCab?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kleenax, Jan 26, 2020.
  1. Jan 26, 2020 at 4:00 PM
    Kleenax
    Kleenax [OP] Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    Borla Model #14945
    It's advertised as ONLY fitting the ExtraCab w/Short box. Anyone ever install it on a long box XtraCab and add a little extension?
    GQ7227 likes this.
  2. Jan 26, 2020 at 4:04 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i just put one on last year, let me check my part #
    it was a perfect fit
    part # 14597
    this won't fit yours?
    i guess mine might have a different exhaust size spec since I only have one cat
    if there is a difference, nevermind!
  3. Jan 28, 2020 at 8:45 PM
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    I installed a Borla #1497 on my 98 ext cab. According to Borla’s web page that is all they have for Tacomas.
    I doubt that you would need any type of extension.
    Might depend on what year they offered a double cab then they added a long bed designation. I’m pretty sure that the last long beds were in the mid to late 80’s 86” long.
    I did have some drama lining up the flanges on the TRD header- bolt hole axis was at 11 & 5 o’clock, had to get a flange welded on the Walker cat so I could match it all up, still cost less than the OEM cat, so it was worthwhile.
    Good luck
    Kleenax[OP] likes this.
