bosch distance plus oil filter
Discussion in 'Technical Chat' started by linkfeeney, Apr 15, 2010.
  1. Apr 15, 2010 at 5:28 PM
    linkfeeney
    linkfeeney [OP] Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    anyone use this new filter from bosch on tacoma!
    they are heavy... but they sell for like $13.50 on advance auto parts...
    cheaper on Amazon...
    worth it?
  2. Apr 15, 2010 at 11:24 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2019 SR/SX Tacoma Access Cab 4x4 3.5L
    Not worth it to me. I would just stick to a OEM filter.
    Only thing these high dollar filters do is lighten your wallet.
  3. Apr 16, 2010 at 3:02 AM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    I dont mind spending the money if it has longer intervals for the winter...
    i hate changing oil in the freezing cold... :(
  4. Apr 16, 2010 at 3:34 AM
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    I've got one in my truck now, paid $13.50 at Advance Auto. I also bought a Mobil 1 M1-209 oversize filter for my next change. The Bosch claims double capacity over other filters, but I'm assuming that's across the same size filter. I figure an oversize will have increased capacity over the standard filters.
    It'd be interesting to see someone hack one up!
  5. Apr 16, 2010 at 4:22 AM
    VTDave
    VTDave Well-Known Member
    Vermont, USA
    05 Access Cab 4x4 Base 5sp Man, 16 DCSB 4x4 Sport 6sp Man
    One thing I've noticed is that the OEM (meaning: Bosch, Mann) oil filters are enormous for European cars where an extended drain interval is specified, e.g., 10k-20k miles. I guess the thinking is that you need tons of surface area to filter out 20k worth of crap.
    If I were to leave a filter on the Tacoma for 10k (which I'm not planning to do), I'd want it to be one biga$$ filter.
  6. Apr 16, 2010 at 7:26 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    I have the puralator oversize pureone on my truck now
    its a HUGE filter.
    the bosch distance plus was heavy... It heavier than than the puralator pureone.... does heavy mean something good???
    I have the OEM oil filter that I order thru a VA toyota dealer that was MADE in japan... they were expensive too and they are SUPER hard to get!
    I would like to cut one up but they are too expensive to cut thou...
    so how's the bosch? any difference??:D
  7. Apr 17, 2010 at 12:03 AM
    Hootbro
    Hootbro Omnipotent
    Delaware
    Many of the European cars run a way higher PSI ratings in their engines than American and Japanese engines. They also have higher spec call outs for their oils and usually require synthetics to meet those specs. That is why they run the longer OCI's on average.
    Also, to those running oversize and non Toyota filters. If you have a filter failure and damage occurs while in warranty, Toyota is going to refer you to the filter maker for restitution on repairs. The filter maker can also deny liability if you use a filter that is not cataloged to your specific make and model.
    Toyota trucks by and large have bigger than average oil capacities and oversize filters really do not give you much if anything in terms return on your extra expense.
