Bosch LSU 4.9 PN cross reference and compatibility
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Jul 19, 2017.
  1. Jul 16, 2024 at 11:37 AM
    #41
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    There were some variations in plug style or overall size of the plug between part numbers, not just length of wiring. I only know this because as I would search for more part numbers I would find that some were MASSIVE in comparison to what is needed for the widebands.
    Anyone looking to pick up your sensors should definitely make sure their plug is the same size and same style prior to picking it up from you. The wire length is easy to deal with.
  2. Jul 16, 2024 at 11:47 AM
    #42
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I just wanted to put this out there, the sensors, Bosch, Denso, NTK etc are usually not the problem but the controllers in aftermarket gauges tend to be pretty shoddy and they will run the heaters at too high of a duty cycle or will run them indefinitely when the key is on but engine isn't running. If you still find yourselves burning sensors up think about whether you do key on engine off a lot, as Innovate and AEM (AEM being slightly less shitty) will run the heaters 100% in that situation.
  3. Jul 16, 2024 at 11:49 AM
    #43
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    I know there are massive differences from one sensor part number to the next, and there is no decoder ring length or plug style. But I thought all the 4.0 tacos used the same connector, just a perhaps different length of harness, depending on what they were sourcing from denso for that particular year (denso likes to switch up things to encourage more part numbers). I didn't think that the connector style on the truck changed, unless that was done on the 2.5 gen in 2012?
  4. Jul 16, 2024 at 12:13 PM
    #44
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh wait, you are talking about the stock stuff, and not wideband stuff? That's a horse of a different color. Lol. It may have changed in 2.5 gen because that was when the EPA mandated they perform the revisions on the 1GR with the implementation of SAI and whatnot.
    Without consulting with my diagrams for 2011 compared to 2012 I couldn't say for sure.
  5. Jul 16, 2024 at 12:14 PM
    #45
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It just requires a different method of wiring to where they only be on while the engine is running. I'll bet tapping into the fuel pump relay for power is probably a prime way of wiring up the AEM's so the heater only runs while the pump is on.
  6. Sep 8, 2024 at 8:37 PM
    #46
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Shout out to @12TRDTacoma for this thread and his advice outside the thread. My Speedhut A/FR gauge malfunctioned last week. The gauge "worked" some of the time and some of the time it didn't. When it worked, A/FR readings wandered a bit from what I was used to. When it didn't work, the gauge just sat at 8.5. My first thought was the sensor. Speedhut suggested confirming the gauge's input voltage was at least 13.5V when truck is running/charging (required for what they called sensor warmup) and, if so, sending the gauge back for testing/update before replacing the sensor. My gut told me sensor and Rob concurred, so I pulled the trigger on a new Denso #234-5136, which was the right length for my application. It works perfectly so, for anyone needing a new sensor for their Speedhut A/FR gauge, Denso #234-5136 is confirmed as compatible.
    12TRDTacoma[OP] likes this.
