BOSS Performance Kit
Discussion in 'Toytec Lifts' started by Photosozo, Aug 14, 2016.
  1. Feb 10, 2017 at 10:54 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    Yes the 2.5 diameter shock vs the 2.0 will both achieve the same lift heights.
    Yes add a leafs in the rear.
    SEngolia3 likes this.
  2. Feb 22, 2017 at 5:41 PM
    Wdwrkr
    Wdwrkr Well-Known Member
    Pete
    Nantucket MA
    2016 TRD Off-road DCSB
    None :-((. Yet :-))
    So I have the Boss 2.5 complete lift installed in my 2016dcsb. Over all I'm pretty happy with it. I have added mobtown skids (a complete set), as well ass an sos bedrack, and CVT tent to the bed, and I am loosing lift as I add more weight. I expected this, but as I look into adding plate bumpers front and rear, with a tire carrier in the rear I am afraid I will loose to much. So my question is what are my best options to add some strength to the rear springs, and when I do so can I just crank up the front coil overs, or should I be looking into 700lb coils up front as well. I am building it more as for overlanding purposes then hardcore off road, but when doing the prior, one sometimes encounters the later.
    Thanks in advance
  3. Feb 22, 2017 at 5:43 PM
    ToyLett
    ToyLett Well-Known Member
    Kitsap County, WA
    2017 Double Cab TRD Off-road
    I am about to purchase, and will apreaciate the feedback as well!
  4. Feb 23, 2017 at 7:07 AM
    Toytec Lifts
    Rocky Mountains
    The 2016+ Tacoma's are a bit heavier of a truck to start out with. If you do plan on adding some weight to the front of it you definitely could upgrade to the 700lb coils in the front to help keep a firm ride and less pre-load. If you plan to keep the front stock you can stick with the 650lb coils. I do have 700's in stock but I do only have silver coils. As far as the rear, is the weight going to be constant? If so i would say going with a full OME leaf pack in the back WITH the OME add a leaf to hold the extra weight and keep the lift. The OME in the rear ride very nice and would match well with 700's in the front.
  5. Feb 24, 2017 at 9:54 PM
    yota2014
    yota2014 New Member
    nick
    FL
    2019 TRD Sport 4x4 dcsb
    So Im looking to get a 3in lift but not sure which one to go with. i have a 2014 dc 2wd tacoma and use it mostly driving on the highway to get to work but i also tow a bass boat on the weekends and don't want any problems while doing either one. which one of your lifts would offer the smoothest ride without breaking the bank?
  6. Mar 9, 2017 at 1:42 PM
    Toytec Lifts
    Rocky Mountains
    If you plan on towing getting one of the kits with the full leaf pack would be the best for towing, unless you wanted to put an airbag system in the back.
  7. Mar 6, 2018 at 7:08 PM
    wilson704
    wilson704 Well-Known Member
    Wilson
    2013 Tacoma
    I’m deciding on which rear shocks to get. Toytec boss 2.0 with resi or the toytec boss 2.5 without resi. Beside the diameter, Is there a difference in performance?
  8. Mar 7, 2018 at 6:53 AM
    Toytec Lifts
    Rocky Mountains
    The 2.5 rear shocks will be a Completely rebuild-able shock. The resi 2.0 will not be.
    Shoot me a pm and I can get you squared away on pricing.
    -David
  9. Mar 14, 2018 at 7:53 PM
    Erex32
    Erex32 New Member
    2017 silver
    i am new here but i am about to get the Toytec Boss performance Lift i dont know what will be good on the rear if i should go with Toytec Progressive Add-Leafs, or just the 1.5" block kit? i will not be doing anything crazy just darlly driving and maybe sometime off road
  10. Mar 15, 2018 at 7:01 AM
    Toytec Lifts
    Rocky Mountains
    The progressive 3 pack AAL will be better for longevity of your rear leafs along with giving you the proper lift and maintaining proper payload on your leaf pack.
    The block will not change your ride quality but will, overtime, flatten out your leaf pack. Especially if you are going to be loading down the Tacoma.
  11. Mar 29, 2018 at 9:09 AM
    EMD1
    EMD1 Active Member
    Dave
    Huntsville Al
    2012 TOYOTA TACOMA
    3in OME (887 and dakar packs All Pro front and rear bumpers All Pro skids 255/85/16 discoverer Light Racing upper control arms Wheelers Superbumps (front and rear) All-Pro U bolt flip kit Baja Design lights
    I have a 2012 4door Tacoma, with all pro apex bumper (aluminum), steel skids, and warn M8-S 8000. I'm currently running the OME front (887) and rear, with Dakar springs. Happy with the set up, but its starting to sag in the front with everything I have on the truck. I see that toytec carrys a lot of different brands of coilovers, so I'm hoping to get some feedback on what to get.
    My truck is a DD, but I do like to trail ride on the weekends, but I don't bash my truck.
    thanks
    Toytec Lifts likes this.
  12. Apr 22, 2018 at 7:06 AM
    Yota105
    Yota105 Active Member
    Jeremy
    Nashville
    15 MGM DCLB 4X4 (work in Progress)
    Just need more $$$ and time!
    Is there any noticeable performance gains by going with the 2.5 resis in the rear vs non reservoir w/ OME leaf pack for a daily driver that will only occasionally be offroad? I also tow frequently so just trying to get the best on road ride with decent off road performance.
  13. Aug 31, 2018 at 1:21 AM
    trail medik
    trail medik Active Member
    brian
    2014 pyrite mica trd
    none yet, and I stress YET
    I think the OME 886 springs are heavier rated and should get your front back up. Check the web site for spring ratings and specs
  14. Sep 4, 2018 at 2:37 PM
    jaysword
    jaysword Member
    2010 DCLB
    I have a 2010 DCLB with 130,000 miles that I am thinking needs original suspension updated. Since I’m going to do this I thought I might as well add some lift also. Nothing drastic as I rarely go off road but would like maybe 2”-2.5” of lift. What suggestions can you give me Toytec?
    Thanks
  15. Nov 27, 2018 at 3:00 PM
    #35
    Trobber76
    Trobber76 Member
    Travis
    2019 Tacoma
    I am new to owning Toyota’s. 2019 Tacoma trd off-road. It’s only got 40 miles on the odometer. I drive Toyota’s at work. I had some question about getting the right lift. I was looking for 2 to 3 inch lift. I will be getting a shell. Fiber glass. I will be trailering a flat fender Jeep 2300 lbs. along with a pop up trailer. Don’t know weight. Not rock crawling, With 4 wheeling. The Jeep Willys be doing a little more challenging.
    Do you recommend AALs? Or new springs? Or blocks? Not lookin to put big tires on. Maybe 31 inch max. Without needing to modify.
    Also with upgrading with you lift will I void my warranty? I do know there is a forum about it. Just wondering if you might know. I do know the risk of raising it with tss.
    Was thinking you might have a recommendation and more questions.
  16. Feb 21, 2019 at 4:29 PM
    #36
    ovrlandfam
    ovrlandfam Active Member
    10' dbl cab TRD sport
    Trail gear tube rear bumper, Westin brush guard,
    Toytec- some questions for ya..
    Truck is a 2010 DCLB TRD SPORT with 3” Procomp lift. Coils in front with block in back. I have no complaints on this kit but want to upgrade to your product. BUT I’d like to keep the procomp front coils to save money. Would you recommend a shock to use with the current coils I have and a rear leaf/shock set up?
    If the idea is a totally stupid one let me know
    I’ve had the rear leafs dealer replaced last year. I have a MobTown front recovery bar and winch goes into the front receiver when needed. On the bed I have bed bars that hold my tent axe shove hi lift etc year around with steel trail gear tube bumper. It’s also my daily driver. Tires are 255/80/17 coopers
  17. Feb 26, 2019 at 7:14 PM
    #37
    Wippa411
    Wippa411 Member
    2013 Blue Tacoma SR5
    3” Toytec Lift
    New Member here. Just Lifted my 2013 Access Cab w/ a BOSS Toytec. Ko2 265/70/17.B1B43088-C684-4A79-BA4B-161927325B67.jpg 17797F02-3165-4999-8EF6-874F054268CC.jpgC370FF06-6F3A-4712-A842-97CAC5A46272.jpg
    Kolter45 and ovrlandfam like this.
