Botched TSB install - Help Please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by speedydave, Dec 14, 2011.
  1. Dec 14, 2011 at 5:11 AM
    speedydave
    speedydave [OP] Well-Known Member
    Dave
    Hickory, Nc
    Mustang GT
    Does anyone know the part number for the original 3 leaf packs? Does the TRD have different leafs than a non-TRD.
    I have read the TSB and it specifies parts:
    48210-04570
    48210-04210
    I just had it done, and got new 3 leaf packs. I think they are different than the ones I originally had, but I'm not sure. The overload leaf appears to be thicker, and the design appears different.
    The parts they used for mine are:
    48220-04191
    48210-04551
    I suspect these are identical replacements for what was already on the truck I am very disappointed.
    The TSB number on the work order is #035-10, I think it is a typo for the correct TSB # 0359-10.
    I guess I need to go back to the dealer today, I am really upset.
    What should I do?
  2. Dec 14, 2011 at 5:11 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    How about only start ONE thread on the subject!!
  3. Dec 14, 2011 at 5:16 AM
    speedydave
    Dave
    Hickory, Nc
    Mustang GT
    I intended to delete the other one, I apparently cannot. I reported it, now it is gone.
  4. Dec 14, 2011 at 5:26 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I could be wrong, but I thought for the TSB you got a 4 leaf pack?
  5. Dec 14, 2011 at 5:31 AM
    speedydave
    Dave
    Hickory, Nc
    Mustang GT
    That's the issue here, I did not. I am trying to determine what I did get.
  6. Dec 14, 2011 at 5:50 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Ya, I'm not completely sure, but I know for the 2010's it was a 4 leaf pack for the TSB. I don't think it would be different for the 2011's. Maybe try calling the dealer and talking to a manager or call Toyota Corp. and see what they say. :confused:
  7. Dec 14, 2011 at 12:49 PM
    Tacoma Mike
    Southern Maine
    Idiots put the same springs on instead of your correct TSB spring numbers.
    They need to make it right with correct springs.
  8. Dec 14, 2011 at 2:30 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    This is why it is important to have the leaf spring TSB memorized and know exactly what to expect.
  9. Dec 14, 2011 at 5:02 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Count the leaves you don't even have to get under it.
  10. Dec 14, 2011 at 5:11 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    OP, The TSB spring part numbers are clearly listed on the TSB document.
    Get those part numbers and simply compare them to your current springs.
    The original packs were 2+1 configuration.
    The TSB springs are 3+1 configuration.
    3+1 means 3 normal leaves and one overload leaf.
    When you stop panting and crying go back out verify. :p
    Edit:
    After further review, yeah it looks like you have the wrong springs.
    Make them fix their f*ckup.
    When they get done undoing their f*ckup make sure that the TSB springs are on the correct sides.
  11. Dec 14, 2011 at 9:12 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I had the TSB done at Reno Toyota, came back with 3 leaves.
    I was pissed, they wouldn't help me.
    Ended up letting corporate toyota know. Nothing was ever resolved so I said FU toyota and bought an AAL. Then dakars, fuck those stock leaves.
  12. Dec 15, 2011 at 5:14 AM
    speedydave
    Dave
    Hickory, Nc
    Mustang GT
    I went back and had a lengthy discussion. New parts should arrive soon.
