Both Door Handles Broken on the Outside
Discussion in '1st Gen. Tacomas (1995-2004)' started by mypoortruck, Jan 4, 2022.
  1. Jan 4, 2022 at 9:20 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I don't necessarily agree with that. The drivers side gets used significantly more than the passenger side over the course of 20 years... The portions of the handles that are breaking aren't exposed to the sun unless they are open, so the UV degradation is not a likely culprit. If my drivers side broke, I wouldn't rush out and replace the passenger side.
  2. Jan 5, 2022 at 7:46 AM
    JerZ1980
    JerZ1980 Member
    98 Tacoma 2.7 4x4
    I can still get in the broken one so I've been putting it off. Not being able to open either would definitely suck though.
  3. Jan 5, 2022 at 7:50 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    The passenger side breaks just as easy even unused so if you want to risk it then by all means.
  4. Jan 5, 2022 at 8:38 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Probably doesn't help much in icy weather, but both mine broke, so when I replaced them I took it apart, door panel and everything I could get to and lubricated the crap out of it so it so it worked with very little effort.
    Gyrkin and Bivouac like this.
  5. Jan 5, 2022 at 8:44 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    I did this but left it in the truck…with my keys
  6. Jan 5, 2022 at 9:18 AM
    Bob12321
    Bob12321 Well-Known Member
    Robert
    That kit above is not a good kit for these trucks....get a real ( slim jim ) works great on older vehicles
  7. Jan 5, 2022 at 4:29 PM
    Trowbocop
    Trowbocop Adventurer
    Nashville, TN
    03 Tacoma SR5 4x4
    SO helpful. Nice. Easy solution to a daunting situation. Good on ya mate :cheers:
    treyus30[QUOTED] likes this.
  8. Dec 19, 2023 at 3:15 AM
    skinnypedal
    skinnypedal New Member
    99 Gold Access Cab
    Just had this problem this morning. Entire handle and arms came out though, so nothing to screw into to pull. Flat head screw driver in top right corner of driver door and a coat hanger got me back in. Passenger side was already broken when I got the truck, rear slider has yard stick Charley-bar, so couldn't go that way either.
  9. Dec 19, 2023 at 3:32 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    FYI, silicone your door seals well a couple times in the winter, it's why I have never broken a door handle in [more then a few] decades of driving up north. Dry door seals stick like week old oatmeal.
    Fantastic11 and Madjik_Man like this.
  10. Dec 19, 2023 at 7:04 AM
    MT-98
    MT-98 Well-Known Member
    Montana
    98 Tacoma
    Sorta Stock
    I'm glad this got resurrected, if just for the link to the all metal door handle upgrade. I had this happen a few winters back. I definitely default to OEM, but the price difference between OEM and aftermarket handles was huge...And there's either OEM, or dirt cheap. No mid-range. Both the dirt cheap handles broke again the next winter, so I finally went with OEM. But in all my internet and Amazon searching, I never found those metal handles.
  11. Dec 19, 2023 at 7:28 AM
    Fantastic11
    Fantastic11 Well-Known Member
    1997 3.4L 4WD / 1996 3.4L 5-Lug
    There are a couple of points inside the door that need greasing once in a while, too. I have seen the handles break because things aren't moving freely inside as they should.
    Gyrkin likes this.
