both headlights dead!! HOW?? help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bcmedic, Nov 4, 2010.
  1. Nov 4, 2010 at 7:13 AM
    bcmedic
    bcmedic [OP] Well-Known Member
    last night i went to turn on my headlights like any other night. and they wouldnt come on. the fog lights would just flick on then turn back off instantly. i can hear the headlight relay going. i havent had the chance to take my multimeter and find out where the power is/isnt. tailights are on, even though headlights arent on with the switch on the on position. DRL's turn off like supposed to when headlights are on the on position....so bizarre
    yes fuses are intact.
    thanks for the help
    have ddm tuning 35w hid on both fogs and headlights.
  2. Nov 4, 2010 at 7:20 AM
    cam-shaft
    cam-shaft Well-Known Member
    Pacific Northwest
    DCTRDOFFRD
    Your problem is that ddm tuning junk. I tried that stuff and it lasted for a short period but it is cheap. Nothing like being up in the middle of the mts at dark and you cannot get your headlights to work.
  3. Nov 4, 2010 at 7:30 AM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Check voltage before and after the ballasts
  4. Nov 4, 2010 at 8:37 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    There's plenty of people running DDM's with no issues at all.
    Keep in mind they have a lifetime warranty as well.
  5. Nov 4, 2010 at 9:07 AM
    bcmedic
    I agree. With both dying at the exact same time seems a little more suspect than the ballast/bulbs. I will check regardless. Could it be the relay??
  6. Nov 4, 2010 at 9:42 AM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    That is also a sign the voltage regulator is going out. Have the alternator and voltage regulator checked.
  7. Nov 4, 2010 at 9:54 AM
    bcmedic
    It's got 20,000 miles. Hardly time to already be failing.
  8. Nov 4, 2010 at 10:00 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Might also want to check the output from the relay when the lights are switched on. Relay could be flipping with coil, but power contacts to lights may have opened.
    Don't know anything about the DDMs.
  9. Nov 4, 2010 at 10:02 AM
    jlvhrse
    jlvhrse Well-Known Member
    Jen
    SoCal SGV
    2009 TRD Sport 4X4 Long Bed
    LSK front and rear LT and stuff
    Same thing happened to my HID headlights... never found the problem just took them out and went back to stock until I can get a whole new set up...
    although mine started turning off one at a time randomly but would turn back on if I turned em off and back on.. it got progressively worse until neither would work at all.
  10. Nov 4, 2010 at 10:04 AM
    inouk
    inouk Well-Known Member
    Sounds like a defective relay, I would check it first.
  11. Nov 4, 2010 at 10:21 AM
    bcmedic
    Not the relay. Took mine dropped it in my neighbor's and took his into mine. Still not going. Voltage is good till the fuse box. Gotta go up work. That's as far as I got for now
  12. Nov 9, 2010 at 12:15 PM
    gorilla33
    gorilla33 Stock Radiant Red
    East Tennessee
    05 trd sport
    I have the a similar problem. Lights do not come on. I can restart my truck and then try the lights again and that works most of the time. Any ideas?
