Both Headlights OUT...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OffRd 5TRMTPR, Dec 14, 2016.
Thread Status:
Not open for further replies.
  1. Dec 14, 2016 at 7:58 AM
    #41
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
  2. Dec 14, 2016 at 8:45 AM
    #42
    OffRd 5TRMTPR
    OffRd 5TRMTPR [OP] Well-Known Member
    2016 White Tacoma TRD Off Road
    Its a plug and play kit. Uses factory wiring harnes
    FYI - was a blown fuse. Dbags tried getting me with the $55 diagnostic and I told them I never agreed to a diagnostic prior to and they needed to consult with me prior to running it. They didn't and tried slapping me with a $65 bill for 2 $.70 fuses. 5 minutes of explaining to the guy how to follow directions they waved the fee. Though i will be looking for a relay kit to run to the battery as opposed to factory wiring harness here shortly.
  3. Dec 14, 2016 at 8:48 AM
    #43
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Well atleast that was the issue and not something worse. I would def contact the seller of that HID kit first and see if they offer an optional relay harness for it. If not, I would be hesitant to throw someone else's relay harness on there unless you know they have good compatibility as it would suck for the relay to not have the right limitations and still smoke your stock fuses.
    Coot
    eccracer104 likes this.
  4. Dec 14, 2016 at 9:42 AM
    #44
    potmilkz
    potmilkz Well-Known Member
    luis
    17 Tacoma 4x4 longbed
    as a standard... if something electrical is not working.. always check the fuse first.. thats first culprit..
    also please put a relay kit.. and get a better hid kit like morimotos.. those chinese ebay kits do more harm than anything.
    #44
    LTacoman, wilcam47 and Coot83 like this.
  5. Dec 14, 2016 at 9:56 AM
    #45
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    So, you put in garbage HIDs, didn't use a proper harness, couldn't be bothered to spend literally 30 seconds checking the fuse yourself, and got upset when the dealer tried to charge you a mere $55 for diagnostics? Talk about being an unreasonable ass.
    You're not paying that $55 for the 70-cent fuses. You're paying that $55 for the decades of experience that analyzed your problem, confirmed it, fixed it, and ensured you didn't fuck up anything else on your truck.
  6. Dec 14, 2016 at 10:05 AM
    #46
    TacoMan2017
    TacoMan2017 Well-Known Member
    Ouch...chill pill on it's way!
  7. Dec 14, 2016 at 10:08 AM
    #47
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I question whether they really confirmed anything more than toasted fuses, but Im biased towards Toyota service. You might win the salty award for the day.
    Coot
  8. Dec 14, 2016 at 10:10 AM
    #48
    0210
    Vancouver, BC
    Probably not, but just having a mechanic look under your vehicle is worth something. If the OP came in and said "I want you to replace my headlight fuse," that's a 70-cent job. If the OP said "my headlights don't work, please fix," that's a diagnosis job.
    Coot83[QUOTED] likes this.
  9. Dec 14, 2016 at 10:13 AM
    #49
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Yea you do got a point. Considering it sounded like it took more than a few minutes I could see that. Well hopefully OP learned where the fuses were, I would expect this to repeat itself until he got a new relay added or a new kit.
    Coot
  10. Dec 14, 2016 at 10:16 AM
    #50
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Its the American way...;)
    Fuse/s would have been the first thing to check...easy to do IMO...
    Hank Heel, Jester243, 1bad2k and 2 others like this.
  11. Dec 14, 2016 at 10:56 AM
    #51
    Ice8
    Ice8 Well-Known Member
    Vancouver, BC
    2017 MGM Tacoma TRD Off Road SB
    A few listed in the signature
    Agreed it was user error and could have all been avoided if he wasn't too lazy to either
    A) Remove his HID kit which takes 15 minutes Max and preserve his warranty
    B) Check the fuse which would have been my first thought
    C) Run the wiring harness which is negligible in cost to his cheap Chinese HID kit
    Simply don't give the dealership a reason to void your warranty and buy quality components. Vendors like TRS and Xenondepot didn't get their reputation overnight selling garbage. And yes I'm aware some people have issues with the TRS kit.
  12. Dec 14, 2016 at 11:58 AM
    #52
    Howanic
    Howanic Well-Known Member
    Utah
    2016 TRD OR Double Cab 4X4 A/T Inferno
    If the after market lights made the problem then they aren't fucking anyone, just doing their job.
    Hank Heel, 1bad2k, 0210 and 2 others like this.
  13. Dec 14, 2016 at 1:45 PM
    #53
    Large
    Large Red
    I agree .. but a pair of 35w ballasts / hids aren't the problem there if they were installed correctly
    Howanic[QUOTED] likes this.
  14. Dec 14, 2016 at 2:02 PM
    #54
    Toytaco2k17
    Toytaco2k17 Well-Known Member
    Kenneth
    Chapmansboro Tn
    2016 Nissan Titan XD Pro4x Diesel
    Stock
    I would of checked the fuses, first. If that was not the issue, I would of spent 15 minutes removing the HID kit before going to the dealer in my opinion.
  15. Dec 14, 2016 at 3:24 PM
    #55
    potmilkz
    luis
    installed correctly and shitty product are two different things.. just because something was installed correctly doesnt mean it cant go wrong..
  16. Dec 14, 2016 at 4:34 PM
    #56
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    How do we know it was installed correctly? He can't even check a fuse.
    Also the OP wants the dealer to check the fuse. Do a diagnostic and not pay for the time taken. He is lucky they waved the charge.
    Hank Heel and 1bad2k like this.
  17. Dec 14, 2016 at 4:41 PM
    #57
    Ice8
    Vancouver, BC
    Agreed if you can't take 15 seconds to check it fuse or don't know how to; I don't feel you have any place wiring or installing a HID kit.
    Herniator[QUOTED] likes this.
  18. Dec 14, 2016 at 4:44 PM
    #58
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    If i were you i woulda never mentioned the hids and said my headlights stopped working.
  19. Dec 14, 2016 at 4:51 PM
    #59
    kerrdog
    kerrdog Well-Known Member
    2016 trdor mgm
    Reasons like this is why I don't modify my truck. There is nothing wrong with the lights that come with the truck in my opinion.
    Garyji and Taco Addiction like this.
  20. Dec 14, 2016 at 5:16 PM
    #60
    AustinNative
    AustinNative Swollen Member
    ATX
    2017 MGM TRD Sport DCSB
    Maxtrac spindles OME 885s Bilstein 5100s all around (adjustable front/extended length rears) Maxtrac rear blocks Headstrong Taco lean spacer OME CBD SS brake lines InsaneFab CMC 18x12 Fuel Hostage 35x12.50 Maxxis AT 1.25" Spidertrax spacers in the rear Llumar Ceramic Tint (5% Rears & Back / 18% Fronts / 50% Windshield) Toyota Tri-Fold bed cover and OEM bed mat Triple Black Clazzio seat covers WeatherTech laser fit or whatever the fuck they call em Probably other stuff...
    Morimoto for the win. Hands down the best HIDs on the market. Also, when in doubt, have a professional install it.
    Coot83 likes this.
Thread Status:
