Both turn signals goes on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by G*59, Apr 28, 2024.
  1. Apr 28, 2024 at 2:31 PM
    G*59
    G*59 [OP] Member
    Gabriel
    2010 toyota tacoma
    Led headlight, backrack, touch radio, led spot, led bar
    Hi, i recently bought a 2nd gen tacoma like 8 months ago and i change the headlights for led right away.. but yesterday i found out when i put my signals either right or left both of my front turn signals light goes on when my headlight are on.. but when my headlights are off both of my turn signals dont work. But the back signal work as it should. I dont know if the led bulb are the cause of this or maybe a relay?
  2. Apr 28, 2024 at 2:39 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Remove those aftermarket LED headaches and go back to stock. I'd bet your problems will go away.
    TnShooter and Tacos4ever15 like this.
  3. Apr 28, 2024 at 2:44 PM
    RandyLahey
    RandyLahey Well-Known Member
    Southwest PA
    2013 sport 6mt
    Take the led bulbs out of your halogen housings, the only purpose they serve is to reduce light output and blind other drivers, it’s also definitely causing your turn signal issue
