Bottom bolt on headlight assembly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Goosedog, Jun 6, 2013.
  1. Jun 6, 2013 at 10:48 AM
    Goosedog
    Goosedog [OP] Well-Known Member
    I'm trying to remove my headlights to work on them and I can get all but that bottom bolt out. It looks like the bumper has to be off to get to that last one. I gotta be doing something wrong, right?
  2. Jun 6, 2013 at 10:50 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    They are quite a pain. Where you located?
  3. Jun 6, 2013 at 10:54 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Here you go.
    It is a pain in the ass to get out. I went to Lowes and actually bought a cheap metric socket set ($6.00) with a small socket wrench. It was simple then. It is the bolt that sits on top of the lower one as you feel it from underneath the truck. Once you take it out "most" people don't put it back because it is such a pain and it really doesn't seem to be needed.
  4. Jun 6, 2013 at 10:56 AM
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    Glad you brought this up...I'm prepping to do the BHLM next day or two.
  5. Jun 6, 2013 at 10:58 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    You can reach it from the bottom its kind of a pain but it can be done. I've taken mine out a few times. You have to lay under the truck and feel for it.The first time I did it I took the bumper off that takes too long. Once you know how to do it without taking the bumper off it take like 10-15 mins to pull the headlights.
  6. Jun 6, 2013 at 11:01 AM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Yep, huge PITA, but CAN be done from under the truck.
  7. Jun 6, 2013 at 11:01 AM
    Goosedog
    Thanks guys, thats a big help. :thumbsup:
  8. Jun 6, 2013 at 11:51 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    It is much easier if you unbolt the two bolts at the bottom of the fender liner then fold it up against the tire. I have removed mine so many times it seems to take me longer to get the right angle to navigate the headlight out than it does to unbolt it.
  9. Jun 6, 2013 at 11:59 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Very true. A 1/4" drive ratchet and shallow socket isn't bad at all to use in there after you free up some space.
  10. Jun 6, 2013 at 1:56 PM
    RearViewMirror
    Craig Christ
    Honestly I didn't even have to free up any space with the 1/4 inch socket / ratchet.
    I bought a POS set similar to this from Lowes and it worked perfectly. Cost me right around $6 and well worth not having to deal with the frustration.
    Once the bolt loosened up I just used the socket without the wrench to remove it the rest of the way. Took 2 mins tops to find and remove the bolt. Just a thought.:)
  11. Jun 6, 2013 at 5:36 PM
    Boone
    Boone, NC
    Airbags deployed
    I guess my sausage arms couldn't find a easy way in there without takin' a minute to get the inner fender out of the way.
  12. Jun 6, 2013 at 5:37 PM
    RearViewMirror
    Craig Christ
    Lol.... It sucks no doubt!
  13. Jun 6, 2013 at 6:34 PM
    DunhamAll
    DunhamAll Well-Known Member
    Jordan
    Baltimore, MD
    '12 Access cab, MT, TRD OR
    Rear diff. breather, BHLM, Wet Okoles.
    I 3rd the quarter inch ratchet.
    I have a dinky POS kit from kobalt. I first tried my larger ratchets, a wobble, deep drive, kitchen sink, et al... And only ended up cursing and slipping off the bolt. 7 cigarettes later, I grabbed the mini ratchet and the bolt came out in minutes.
    My passenger side bolt was much easier, so practice on that one?
  14. Jun 6, 2013 at 7:12 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    theres 1 screw to remove the little plastic piece under the hdlt, then all 4 screws are easy to reach
