bottom engine cover question
Discussion in '1st Gen. Tacomas (1995-2004)' started by ywen, Apr 28, 2010.
  1. Apr 28, 2010 at 6:53 PM
    ywen
    ywen [OP] Well-Known Member
    So during my oil change, I discovered that of the 4 bolts for the lower engine cover, one of them had rusted and the bolt head broke off. The previous owner used a zip tie in that corner. I'm suspecting that this is why I hear some banging noise when going over curbs.
    What is the best way of extracting the remaining bolt? How much is it for a new engine cover?
  2. Apr 28, 2010 at 6:58 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    lower engine cover? You mean the engine skid plate?
  3. Apr 28, 2010 at 6:58 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    Ur talkiing about the factory skid plate right... autozone sells bolt extractors, never used one so don't know exactly how they work
  4. Apr 28, 2010 at 6:59 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    I would try and drill it out and re tap the threads. Can't really say much more without a pic
  5. Apr 28, 2010 at 6:59 PM
    ywen
    not the front skid plate, but the engine cover towards the rear where there's an opening for the oil drain plug
  6. Apr 28, 2010 at 7:01 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Go to autozone and get an easyout. If that doesnt work you'll have to drill and tap.
  7. Apr 28, 2010 at 7:08 PM
    ywen
    Damn.. just found the part.. its $100 for that thing.. FACK
  8. Apr 28, 2010 at 7:08 PM
    jandrews
    ...Maybe it's because I have a TRD OR, but the opening for my engine oil drain plug is in the rear section of the engine skid plate...
    Granted "skid plate" may be a bit too strong a term for what Toyota bolts on down there...
  9. Apr 28, 2010 at 8:59 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Are you thinking you have to replace the rear skid plate because you (or the previous owner) sheared one of the bolts that holds it on? That doesn't seen necessary from the way you've described the problem.
    Just remove the other 3 bolts that hold the plate on, the use an extractor kit as suggested earlier on the one sheared stud. Probably a good idea to soak the other bolts with WD-40 just in case they are rusted on too before you remove them.
    That second plate is a fairly simple, flat piece. I've seen them get pretty mangled up by getting caught on something when backing up on the trail. Guys usually just take them off, hammer them flat again and put them back on.
  10. Apr 29, 2010 at 6:09 PM
    747 function > form
    1st Gen.
    I deleted the rear piece...makes changing oil much easier/less messy on 1st Gens.
  11. Apr 29, 2010 at 8:04 PM
    ywen
    hMM i'M THInking it's there for reason? the components behind the engine is prolly more prone to damage...
  12. Apr 30, 2010 at 4:34 AM
    Suspiciousmind
    Suspiciousmind Member
    Mark
    NC
    99 Taco 4x4 ext cab
    I've been leaving both of mine off... I'm not off roading and don't miss the extra weight at all...no problems in 70k miles yet.
  13. Apr 30, 2010 at 4:43 AM
    TacomaDan
    TacomaDan Don't go off ninjin
    Daniel
    Woodland, CA
    1996 Toyota Tacoma Fully Not Loaded
    Love, Cobra 29 LTD BT CB w/ A2000 Highgear antenna, FOX/Fabtech Coilovers, Magnaflow
    I just leave mine on because I HEART PROTECTION! an it makes me feel like my truck has the protection of a trophy truck...
  14. Apr 30, 2010 at 6:14 AM
    ywen
    The radiator pokes out underneath the front bumper... at least it does with my 03 bumper..
  15. Apr 30, 2010 at 6:24 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Is the bolt hole open? Take one of the existing bolts out and see if the bolt hole goes straight through. If it does, you should be able to push the broke bolt right out by center punching it and drilling it with a normal drill bit. It will usually grab the bolt and turn it rather than drill through it.
