Bottom rear shock mount
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ROBBS-COMA, Nov 9, 2020.
  1. Nov 9, 2020 at 1:46 PM
    #41
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Id be worried the axle is toast / compromised to the point where you wont have any good weldable material.
    BillsSR5 likes this.
  2. Nov 9, 2020 at 1:49 PM
    #42
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    true, might make a bad problem worse burning a hole in a compromised axle, the $85 hoop mount seems a good option and its DIY able
  3. Nov 9, 2020 at 3:11 PM
    #43
    ROBBS-COMA
    ROBBS-COMA [OP] Well-Known Member
    ROBB
    Bethlehem PA
    2008 TACOMA 4DOOR TRD SPORT 4X4
    NONE YET
    Haven't gotten around to it but trust me, it'll get done...
  4. Nov 9, 2020 at 3:11 PM
    #44
    MGMStudioTaco
    MGMStudioTaco Member
    Trey
    Charlotte, NC
    2018 MGM Tacoma Limited 4x4
    Grande Tires W/Kings
    some JB weld and you will be good
  5. Nov 10, 2020 at 1:39 AM
    #45
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Damn! I am so glad I don't live up in the northern area where rust is such a problem. That is horrible.
  6. Nov 10, 2020 at 8:16 AM
    #46
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Too many questions in my head, on how the welder burnt through the thick axle?
    Jimmyh likes this.
  7. Nov 10, 2020 at 8:18 AM
    #47
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This guy. :rofl: Versatile stuff right there!
  8. Nov 10, 2020 at 8:29 AM
    #48
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Car-part.com. Narrow the search filters to Northeast. Expect to pay about $1000.
    If I were faced with the same problem, I would fabricate a bracket out of either steel sheet or square tubing (i.e. cut it into a 3-sided box) and have it welded on at a repair shop (for example, shops that do mufflers and exhaust). Use the right-hand shock bracket as sizing reference.
  9. Nov 10, 2020 at 9:06 AM
    #49
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Depends how much axle is left vs how much of that tube is made from compressed rust.
  10. Nov 10, 2020 at 11:48 AM
    #50
    BillsSR5
    bill
    2014 SR5
    post #14 pic #2 https://www.tacomaworld.com/threads/crazy-leak-from-the-rear-end-overnight.548948/ I remember su.brat had gotten a leak it looks like the installer may? have tack welded a few spots on the rear axle that resulted in a leak, on a late model Taco. don't know if the same effect would happen to a shock mount weld
    Torspd[QUOTED] likes this.
  11. Nov 10, 2020 at 12:05 PM
    #51
    ohcaltexscar
    ohcaltexscar Out of Huckleberry Licorice…
    Chas
    Southwest Ohio
    2005 DCLB SR5 Prerunner
    IM4x4 2.5" NitroGas - Coopers
    I know this doesn't help but that first picture got me :rofl:
    Sounds like you've got the good advice from the proper guys on here already.
    ROBBS-COMA[OP] and Torspd like this.
  12. Nov 10, 2020 at 12:06 PM
    #52
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ok. I understand more by looking at that. Didn't get to see the front of the trac-bar, but it looks like however the bracket was welded on, plus the forces added to that bracket by the style of trac-bar.
  13. Nov 10, 2020 at 12:07 PM
    #53
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    You can use any shock if they are the correct length. I have seen it with longer billstein shocks. You can get a pair of resi kings for $6-$700 or a set of Billies for half that. Check on Ebay or with some vendors (some have deals on ebay too). DSM has a set of King 12" with Resi for awhile on ebay around $600. But as others mentioned you may want to just get a new or used axle.
    #53
  14. Nov 10, 2020 at 12:09 PM
    #54
    BillsSR5
    bill
    2014 SR5
    I just relooked at the picture of the OPs axle that bad boy is pretty rusted out, not a welding expert but that thing looks compromised as far as how much heat or stress it could take, probably best have a welder shop at least look at it for a pro opinion, theres always plan B, the $85 shock mount hoop setup
  15. Nov 10, 2020 at 8:18 PM
    #55
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    He should of taken better care of his truck,pretty easy too see the rust destroying his axle housing.
  16. Nov 10, 2020 at 8:29 PM
    #56
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
  17. Nov 11, 2020 at 3:27 AM
    #57
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Up here, our trucks rust out. Down there, your boats rust out. Pick your poison. :(
    Torspd likes this.
  18. Nov 11, 2020 at 5:34 AM
    #58
    ohcaltexscar
    Chas
    Southwest Ohio
    I've run KYB on a couple of vehicles in the past, but not on the Tacoma. I never had any complaints. Advance Auto used to sell them when I worked there, I couldn't speak to whether they still carry them now. I only saw a few come back in over the years for issues, and typically user error at that.
    https://youtu.be/25MrIqq_EMo
    Jimmyh likes this.
  19. Nov 11, 2020 at 6:27 AM
    #59
    ROBBS-COMA
    ROBB
    Bethlehem PA
    NONE YET
    Guys, thanks a million for the ideas and input. I have a deal worked out. Going to get another axle installed. Not going to go through the trouble of welding brackets on that axle and have something worse happen. Peace of mind with another axle. Will definitely have it all undercoated too.
    And yes, up here it sucks with the salt and snow..
  20. Nov 11, 2020 at 6:31 AM
    #60
    Fastrat
    Fastrat Well-Known Member
    Fort Walton Beach, FL
    2014 DCSB Baja
    Good call
