Bottomed out the rear TSB today
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bryan07sport, Apr 10, 2010.
  1. Apr 10, 2010 at 8:20 PM
    Bryan07sport
    Bryan07sport [OP] Well-Known Member
    Bryan
    Newark, Delaware
    07 TRD Sport Access 6spd
    Hardwire GPS, 110v power outlet in cab, foglights anytime, mudflaps removed, pa-15 ipod interface, rear leaf tsb, URD short shift, integrated third brake/cargo light, ABS disable switch, BHLM, Dynomax super turbo muffler, Nitto Terra Grapplers 265/70/17, Front Bilstein 5100's at 1.75, Weathertech floormats, sockmonkey bedsides, bestop supertop, spidertrax
    So I was doing some demo for a bathroom side job and put the corian vanity top, pooper, cast iron tub, and ceiling-high tile and morter and steel mesh from around the tub in the back of my truck today. It was sitting pretty low, so i decided to make a dump run. It bottomed out over small dips and whatnot on the highway. 1680lbs. That is officially too much weight. I could hear the cab creaking and stuff while going slowly over bumps. Its the first time i've bottomed out the back. I had 1450 in driveway stone in it and it didn't bottom out... today put it over. Just a heads up. Keep it under 1680.
  2. Apr 10, 2010 at 8:28 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Well the payload capacity is 1430#... what did you expect?
  3. Apr 10, 2010 at 8:36 PM
    Bryan07sport
    Bryan
    Newark, Delaware
    Is it? I honestly didn't know that. I just put shit in it and use it like a truck. If it'll fit back there than load er up. And I still wasn't over the Gross Vehicle Rating, i was short by a few hundred pounds. isn't that what determines the amount of payload you can have? And wouldnt having the TSB raise the payload capacity anyway? I should have preficed this with this is not me bitching. I am not disappointed with the truck or anything. Actually kind of impressed that it took all that.
  4. Apr 10, 2010 at 9:21 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    1,280# per Toyota's website. Consult the your manual for accuracy. It does vary slightly by model. This includes everything loaded in the truck so if you weigh 600 lbs then the capacity is reduced by that amount.
  5. Apr 10, 2010 at 9:25 PM
    dexterdog
    Oly WA
    2012 F150
    The manufacturer determines what the payload capacity is not how much you can fit in the bed.
    The rear leaf spring TSB doesn't increase payload, it only affects how the weight is handled. Try to avoid overloading your truck. It's not good.
  6. Apr 10, 2010 at 9:31 PM
    2K8TACO
    2K8TACO Not only am I a client Im a member.
    JASON
    RAMONA CA.
    Black,auto,2X4,V6,Long Bed
    Tinted windows 5%, Hell Bent 3" lift kit,K&N Airfilter, Trufilter (oil filter), Synthetic oils.
    The rear end of these trucks don't hold sh@t! I put barely any weight in the back and the rear springs bend backward. I would love to put air bags on my truck, I just don't have the $! This is the only fault about my truck, other than that I love it.
  7. Apr 10, 2010 at 9:37 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    That was from Toyota's website, as of 30 minutes ago.
  8. Apr 10, 2010 at 10:25 PM
    kenstar
    kenstar Get a Lil Mud on the Tares
    Ken
    Wrenching in the garage.
    10 4x4 TRD OR
    Pop 'n' Lock, EGR In-Chan, Bakflip G2, 6112, 5160, Dakar Set. Redline hood struts. WildPeak At3. TRD Pro Wheels. Apex Fab Fog lights; Other shit I can't remember.
    :laugh:
  9. Apr 10, 2010 at 11:40 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2010 Double cab 4X4 TRD Sport with JBL
    Redline Tuning hood struts, tinted windows, FX-R HID projector retrofit headlights, AMP power steps
    Sounds to me like you need to move up to a Tundra.
  10. Apr 10, 2010 at 11:42 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    or get a trailer and save your rear leafs , I used to haul a 600 lb tool box every day to work and I flattened my 4 leaf pack , rear is down prob an inch from when I bought it ,
    OZ
  11. Apr 11, 2010 at 6:11 AM
    Bryan07sport
    Bryan
    Newark, Delaware
    doesn't look like it's lowered any to me. And this is only the second time i've had over 1000lbs in it. and I dont like tundras, i like tacomas. usually it's empty, occasionally a motorcycle or mountain bike or tools and small stuff. So whats the difference between Gross Vehicle Rating and payload? Cause the truck came in at just under 3 tons loaded, and the gross vehicle is like 6300 (or thereabouts). I was under the impression that the gross vehicle number was the max your truck is rated to weigh, completely loaded, and I was within that. This is a conversation that should be had over beer. Once again this is not me bitching, just making conversation. i love this truck.
  12. Apr 11, 2010 at 6:16 AM
    Bryan07sport
    Bryan
    Newark, Delaware
    alright alright, i just read the door. it's 5350. oops. so i was over by like 600 lbs. ehh it took it like a champ. Thats why they make big helper leafs and bump stops.
  13. Apr 11, 2010 at 6:18 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    I would be impressed as well if I was able to haul all that stuff as well. I would not make a habit of it, but it is good to know that it is possible. Just another Tacoma FTW moment in my eyes.
  14. Apr 11, 2010 at 6:25 AM
    Bryan07sport
    Bryan
    Newark, Delaware
    I agree man. Thanks.
  15. Apr 11, 2010 at 6:53 AM
    Brunes
    Brunes abides.
    Rotorhead
    Yeah....The truck is rated to carry X lbs (based on the model and options) for a reason- Suspension, braking, cooling, transmission wear- all factor into that. Put your rig under stress like that and you are shortening the life of it drastically.
    Not to mention- You can get ticketed/fined for violating that GVWR IIRC. It's not easy or common for pickups to get on...but big rig truckers get hit all the time if they aren't careful.
    Sumovabish-8000posts!! W00000T!!!
  16. Apr 11, 2010 at 7:26 AM
    dexterdog
    Oly WA
    2012 F150
    That is your vehicle, not his.
    I'm assuming his is a 4wd model so per the website for a '10 model year truck it is 1,305# but I would still suggest referring to the manual as this can change from year to year.
  17. Apr 11, 2010 at 7:35 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    I'll say it again. Tacoma FTW.
  18. Apr 11, 2010 at 7:37 AM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    This. Actually 1295 for my model (DC SB 4x4). But still, the point is...truck was over capacity...you didn't hurt it or anything, I just wouldn't make a habit of doing that.
    The TSB will not increase payload past what's rated...because the TSB was designed to ensure the truck can in fact handle it's rated payload...
