Bought 5w-20...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jrdbrn, May 20, 2010.
  1. May 20, 2010 at 6:46 PM
    jrdbrn
    jrdbrn [OP] Borne Fishing
    Jared
    Louisiana
    '16 Inferno Tacoma TSS
    I bought oil for both my wife's car and my truck and accidentally bought 5w-20 for my truck. I already changed the oil before I noticed I needed 5w-30. Will it hurt anything?
    I just read searching that people don't like the FRAM filters. Did I make a mistake with that as well? What is so bad about them?
  2. May 20, 2010 at 8:50 PM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    You're OK with the 5W-20, just be sure to go back to 5W-30 next time.
    Some Fram filters are very good ( the extended guard ), and some are not very good ( the basic orange can ). But your truck prolly won't blow up because of it, just start using a better filter from now on. The OEM filters are good, as are M1, Pure one, Wix, Napa Gold.
  3. May 21, 2010 at 9:38 AM
    jrdbrn
    Jared
    Louisiana
    Oh well. I bought the extra guard. I've been putting this same filter on my Mazda 3 for 80k miles now and never had an issue since I bought the car. Wondering why people say they have issues?
  4. May 21, 2010 at 9:45 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Considering you have a Louisiana summer coming up I'd seriously think of changing to recommended weight, especially if you do any significant towing. It may not kill the motor but 20w thins out way to much for comfort in an engine designed for heavier weight oil and will contribute to wear.
    If a quality full synthetic it might be OK but I'd still be uncomfortable and drain a couple quarts and top back off with 5W-40 of same brand/type. Mixing isn't the best way to do it, but it's far cheaper than dumping all 5+ quarts.
  5. May 21, 2010 at 9:53 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Don't go there...I've been using Frams ever since high school and never had a problem. My brother also uses them. But I use the extra guard too, ever since I went to 10K drain intervals with synthetic.
  6. May 21, 2010 at 9:57 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    You will be O.K. with the oil.
    Not a big fram fan though.
  7. May 21, 2010 at 11:40 AM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    I prefer WIX, if you are not seeing a dummy light for oil, then it's getting enough pressure and you will be fine.
  8. May 21, 2010 at 2:51 PM
    jonny
    jonny Betty White Edition Heep ZJ
    i have been using the fram filters lately because i am too lazy to go to the dealer and pick up an oem. the extended gaurd ones have worked fine for me. the gray one, not the orange.
