Bought a 04 Transmission for my 01 4x4 Swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tylerb, Feb 18, 2023.
  1. Feb 18, 2023 at 9:30 AM
    Tylerb
    Tylerb [OP] Twowheel
    Tyler
    Missoul MT
    2000 Toyota Tacoma SR5 V6 Manual 4x4 royal jade green
    4x4 conversion, manual hubs on my old prerunner (sold)
    Hey all, I purchased an o4 4x4 tranny for my 01 prerunner as I am trying to do a 4x4 conversion, I noticed that the throttle control line was absent from the 04 tranny and found to my horror that it’s not compatible with my truck… I noticed that there’s a black plug where the throttle line should be, has anyone successfully swapped connectors and been able to use the o4 tranny on there older trucks?
  2. Feb 18, 2023 at 9:34 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  3. Feb 18, 2023 at 9:35 AM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    From what I understand you can do a valve body swap. @Lfaub03 did a good write-up on it here.
    I’d proceed with the rest of your parts acquisition with caution. Maybe read a few more write-ups and build threads. There are other differences between 2.7/I4 and 3.4/V6 trucks. As well as transfer case compatibility between manual and auto trucks.
    Lfaub03, Area51Runner and Tylerb[OP] like this.
  4. Feb 18, 2023 at 9:56 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    You have a rare 2003-2004 ETCS-I transmission. Very hard to find, issue is that it lacks the kickdown cable. I’ve heard the valve bodies could be swapped
  5. Feb 18, 2023 at 10:47 AM
    Tylerb
    Tyler
    Missoul MT
    Gotcha, I can’t add the kickdown cable to the ETCS-I from my 01 tranny? There’s a plug where it should go.
  6. Feb 18, 2023 at 10:52 AM
    04Pre_Runner
    Andrew
    Read the valve body swap thread I linked above.
    He was was able to use a kickdown cable transmission with his 2003 with the ETCS-I. It works both ways and you should be able to use the 04 transmission with your 01.
  7. Feb 18, 2023 at 11:30 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    This is just me but, unless that transmission was in great shape, you could fetch more coin than it'd cost to buy a 2002 and older model.
    04Pre_Runner likes this.
  8. Feb 18, 2023 at 11:36 AM
    Tylerb
    Tyler
    Missoul MT
    Thanks! This answers all my questions, really appreciate the info!
    04Pre_Runner[QUOTED] likes this.
  9. Feb 18, 2023 at 11:38 AM
    Tylerb
    Tyler
    Missoul MT
    It’s in super good shape, it only has 130k miles on it, plus I’m in Montana and very few people have the 03-04 tacos with auto trannys up here, I had it listed for three weeks and had no offers.
  10. Feb 18, 2023 at 12:10 PM
    04Pre_Runner
    Andrew
    No problem. Definitely pay attention to the torque converter discussion in that thread too. Whole can of worms if you start swapping them around.
    Tylerb[QUOTED][OP] likes this.
  11. Feb 18, 2023 at 3:35 PM
    Tylerb
    Tyler
    Missoul MT
    Got it
  12. Feb 19, 2023 at 8:48 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Why not just manual swap it if you're gonna go through all the work of doing a 4WD conversion?
  13. Feb 19, 2023 at 8:50 AM
    Tylerb
    Tyler
    Missoul MT
    Because I can’t find any manual transmissions close by and I’m out of cash, I plan on it eventually though.
    Red_03Taco[QUOTED] likes this.
