Bought a junk yard e locked rear end, is this concerning?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jeg0005, Apr 4, 2019.
  1. Apr 4, 2019 at 11:51 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Install.
    Test.
    Drive.
    If it works...thank us all for the amazing advice. If it fails...I’m sorry what are we taking about again?
    Brice likes this.
  2. Apr 4, 2019 at 12:36 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Back when these were new, it was not uncommon to find chewed up thumbnail sized bits of sheet metal. They appeared to be scrap from a punching operation. The best guess was scrap from the oil baffles in the housing tubes. It almost seemed as if those of us that changed the oil in the first 500-1000 miles were the ones to find the big pieces, others just found the typical beard on the magnet.
    There is a procedure to index a specific tooth of the actuator gear to a specific tooth of the locker rack gear on install. This preserves an over travel feature of the actuator. Easily done with the third on the bench, must pull the long studs if the third is installed in the housing. It is possible to do this "free hand" if you understand all about how the actuator works and where things should be in the fully locked position and extrapolate from there. There are lots of these things out there "one tooth off". They will still work but strength when locked is compromised.
    In the procedure below any battery can be used, they recommend 1.5v for safety in the event of a short. 1.5v will run it slow, many folks use a couple of D cells in series for 3v. I just use 12v (with care).
    With the actuator out of the diff the rotation should be smooth, no binding from lock to unlock and end up in the same position each time. It can be easier to judge this with the slower motion from the smaller batteries. Total transit time for a good actuator off the diff is around 1/2 a second with 12v.
    Brice, jjsul, cruiserguy and 2 others like this.
  3. Apr 4, 2019 at 12:43 PM
    1DVS-BSTD
    1DVS-BSTD is probably confused
    The Corn Is Pretty Good Here
    '03 TRD Off-Road, '22 Poverty Spec
    881's, Nitrochargers, Dakars, SR8's, Duratracs
    Was there any more money in there, or just the dime? :D
    Good idea to take it apart and check it out before installing. I'd wager it's fine though.
    cruxofthebisquit and Jon G like this.
  4. Apr 4, 2019 at 12:45 PM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Only one way to fix that...
    jeg0005[QUOTED][OP] likes this.
  5. Apr 4, 2019 at 2:45 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    either :spending:
    or
    :fingerscrossed:
    I dunno, I couldn't find an imoji for doing your own work and learning as you go...
    jeg0005[OP] likes this.
  6. Apr 4, 2019 at 2:57 PM
    2JHilux
    2JHilux Level 8 Tinkerer
    Denver, CO
    2001 Tacoma Double Cab 4x4
    manual swap in progress
    I'd want to look inside also but those don't look too bad though.
    It probably operates fine.. emphasis on "probably".
  7. Apr 4, 2019 at 2:59 PM
    Rujack
    Usually at little of both, plus these
    :censored::help::pccoffee::yes:
    CrustyTaco and jbrandt[QUOTED] like this.
  8. Apr 4, 2019 at 3:02 PM
    Rujack
    I’d just want to verify. Could very well be nothing to worry about but I’d definitely want to be sure. Not hard to look at a diff and get a lot of good info. Bearings I guess would be hard to inspect visually but just about everything else isn’t.
  9. Apr 4, 2019 at 3:05 PM
    Jon G
    Jon G Hoarding Tacomas one at a time,
    Jon
    St John's Newfoundland Canada
    02, 04 & 07 Tacoma
    Magnaflow 2.5 Catback Exhaust K&N filter
    My type of humour
    1DVS-BSTD[QUOTED] likes this.
  10. Apr 4, 2019 at 3:06 PM
    jeg0005
    jeg0005 [OP] Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
    I’ve got the axle shafts out and I’m going to regroup and do some reading and youtube-ing. I’ll probably pull the e locker and third member in the next couple of days once I know what I’m looking for.
  11. Apr 4, 2019 at 3:12 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    There's a meet or mod day coming up on the 20th, might be able to get some help from the locals.
    cruiserguy likes this.
  12. Apr 4, 2019 at 3:13 PM
    jeg0005
    Jon
    BHM, AL
    4/20? I’ll try to make it bc I have a few taco issues going on right now:annoyed:. I need to jump back on the Alabama thread and see the deets
  13. Apr 4, 2019 at 3:14 PM
    jeg0005
    Jon
    BHM, AL
    This site has been an awesome F’in resource though, thank you all!
    cruiserguy and Rujack like this.
  14. Apr 4, 2019 at 3:26 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    They changed it to the 27th, but it's a meet, so not any wrenching. Might ask on the main thread though. I'd offer help, but can't make it up there for awhile.
  15. Apr 8, 2019 at 6:18 PM
    #35
    jeg0005
    Jon
    BHM, AL
    recommend any videos?
  16. Apr 8, 2019 at 6:23 PM
    #36
    jeg0005
    Jon
    BHM, AL
    Am I going to need to pull apart the actual ring gear/spider/pinon or would I be able to see what I need to see with just pulling the 3rd member?
  17. Apr 8, 2019 at 6:32 PM
    #37
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    You'll be able to tell if the spider gears have alot of slop in them.
    cruxofthebisquit likes this.
  18. Apr 8, 2019 at 6:33 PM
    #38
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    If its damaged I'll have a 3rd up for sale pretty soon.
  19. Apr 8, 2019 at 6:34 PM
    #39
    jeg0005
    Jon
    BHM, AL
    If it's damaged, I'm going to just use it as an opportunity to regear, I suppose.
    1st4x4[QUOTED] likes this.
  20. Apr 8, 2019 at 6:35 PM
    #40
    1st4x4
    sam
    Torrance
    That works also.
