Bought a new motor. Feeler for write-up
Discussion in '1st Gen. Tacomas (1995-2004)' started by natemoore2088, Apr 24, 2012.
  1. Apr 24, 2012 at 10:00 PM
    natemoore2088
    natemoore2088 [OP] Well-Known Member
    Nate
    Idaho
    '97 Tacoma 2.7
    2" lift Pre-runner bumper Deck Plate Doug Thorley header Cherry Bomb
    Hey guys, I just ordered a motor form my '97 3rz from engineandtransmissionworld.com. The motor is used with 41k and has been cleaned up, compression and leak-down tested. I will be pulling my blown up one and installing the new one in a couple weeks, along with a DT header and a flex-fan from LCE.
    Would you guys be interested in a full write-up for doing a motor swap for the 2.7l?
  2. Apr 24, 2012 at 10:08 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    Why not? Never too many write-ups.
  3. Apr 24, 2012 at 10:10 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
  4. Apr 24, 2012 at 10:39 PM
    boshak
    boshak Well-Known Member
    Tony
    Southern California
    2003 Manual 4x4 5VZ-FE
    OME 881's, Wheeler's 5-leaf pack, Bilstein 5100's
  5. Apr 25, 2012 at 10:31 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    While I would not be against it personally because it would benefit someone, having to stop and take pictures and position everything is going to add some serious time to your swap. I recently documented the process of replacing carpet on a DC Tacoma, but honestly there are at least 60 pics/steps involved and the whole process was VERY time consuming. In the end it's up to you, I'm just not sure there are enough members swapping engines enough to make it worth your time. But don't let me sway you, just a heads up.
  6. Apr 25, 2012 at 11:04 AM
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    Clemson
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Window Rain Guards Bed Liner Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges
    how did your previous blow up?
  7. Apr 25, 2012 at 11:13 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    I am interested. Might swap in the future.
  8. Apr 25, 2012 at 8:36 PM
    natemoore2088
    Nate
    Idaho
    '97 Tacoma 2.7
    To make a long story short: Previous owner swapped the distributor engine into my truck which has a coil ignition. He jerry-rigged it enough to work but the timing was never quite right. Truck would misfire consistently while accelerating but was still drive-able. I was pulling a hill in third, well below red line and started hearing awful noises from the engine compartment. Pulled over and it sounded like valves making contact with pistons, or something making contact with cylinder head. The motor still runs but every time I fire it up it sounds worse than before, somethings gonna seize if I keep running it. I could possibly replace the head and make it work, but decided to just swap the correct motor into the pickup rather than have to worry about whatever else the jackass who owned it before me might have jerry rigged.
    I didn't know about the engine swap when I bought the truck. It had an o2 sensor code and a camshaft position sensor code. Those sensors seemed like relatively easy fixes and the guy who sold it to me knocked $800 off for the codes. Should have taken it to a shop but got too excited and pulled the trigger before I knew all the details. Now I am dealing with the consequences.
  9. Apr 26, 2012 at 5:23 AM
    fsusteve
    fsusteve Well-Known Member
    Naples, Fla
  10. Apr 26, 2012 at 6:22 AM
    wesrunner
    wesrunner Team 4Runner
    Wes
    Louisiana
    It's paid for.
    1999 T4R 4WD V6, Deck plate, B&M trans cooler, LED guages and dome lights, LED reverse lights, 2.5" spacer lift, highway tires.
  11. Apr 26, 2012 at 11:50 AM
    CUtacomaTIGER
    Clemson
    well that sucks that the dude wasn't honest with you. best of luck. fyi i don't think these engine are interference engines so no valves could be slapping pistons
  12. Feb 18, 2013 at 4:09 AM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    1995 Tacoma 4X4
    ARE Impulse Shell, BFG AT KO's
    Thread revival.....
    So did you ever get another engine put in your truck?
  13. Feb 18, 2013 at 10:22 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    i would love a write up
