Bought a ScanGauge, It Doesn't Work!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by saf023, Feb 7, 2010.
  1. Feb 7, 2010 at 2:47 PM
    saf023
    saf023 [OP] Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    Just tried hooking up my ScanGauge for the first time. I took it right out of the box, installed the Ethernet looking cable in the back of the ScanGauge, turned the ignition on but short of starting the truck, plugged the OBDII cable into the trucks ECM and nothing.
    The backlight of the ScanGauge comes on (but goes out on its own) and nothing ever comes up on the display. No "connecting" nothing.
    Anyone have this problem?
    Any suggestions?
  2. Feb 7, 2010 at 2:50 PM
    misterquad
    misterquad Well-Known Member
  3. Feb 7, 2010 at 2:57 PM
    saf023
    East Coast
    I bought on Amazon.com. Never heard of Vatozone, is it an automotive parts place?
  4. Feb 7, 2010 at 2:57 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    There should be a phone number in the book that came with it. Give it a call, that or take it back to where you bought it and telll them it doesnt work. There is like one year warrenty on them. I had no problems with mine and I love the hell out of it once I got it set for my truck.
  5. Feb 7, 2010 at 3:00 PM
    saf023
    East Coast
    No phone number that I can find. There is an email and an address to send it back to for repairs. You are right, warranty is 1 year.
    Not sure I want it repaired, I want it replaced. It's brand new. It should work!
  6. Feb 7, 2010 at 3:01 PM
    saf023
    East Coast
    Thanks. I know exactly where it is. Any idea what they cost there?
  7. Feb 7, 2010 at 3:05 PM
    jeremiekc
    Jeremie
    Vilseck, Germany
    With stuff like that they normally just replace the whole thing. It is really not worth the time and hassle to diagnos the problem and all that. I wouldnt worry to much about the difference between repair and replace. If you bought it through Amazon you dont have to worry to much about getting ripped off. Definately do not try and repair it yourself. I tried that with a vacumn cleaner and had to end up paying to have it repaired even though it was under warranty since I tried to fix it my self.
    Semper Fi!
  8. Feb 7, 2010 at 3:07 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Not trying to be an a$$ but is it plugged all the way into the port? A loose connection might be why the light comes on and then goes out :eek:
    If you've already tried that, sorry.
  9. Feb 7, 2010 at 3:10 PM
    saf023
    East Coast
    Hey no problem. That is the first thing I checked!
  10. Feb 7, 2010 at 3:14 PM
    ImpulseRed008
    Susan
    SC
    :thumbsup:
  11. Feb 7, 2010 at 3:34 PM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/75-16 KO2
    Normal. Start the engine.
  12. Feb 7, 2010 at 4:18 PM
    saf023
    East Coast
    I started the engine. What's normal; plugging it in and leaving it plugged in for 10 minutes and getting...
    - no pixels energized
    - no letters
    - no numbers
    - no symbols
    - no words
    ...NOTHING? I think not.
  13. Feb 7, 2010 at 4:43 PM
    ksj
    Pacific NW
    265/75-16 KO2
    :confused:
    It is normal for the scangauge not to start until you start the engine. Sorry for not knowing what you meant. Next time I'll consult my crystal ball.
  14. Feb 7, 2010 at 5:46 PM
    JKD
    JKD Well-Known Member
    Have you tried pressing the button with the red circle around it?
    Try plugging the cable into the other "ethernet" (not really) port.
  15. Feb 7, 2010 at 7:04 PM
    saf023
    East Coast
    Thanks. I did try both connector ports (back and side). I also tried pressing the buttom with the red circle. I think they call it the menu buttom. Heck, I tried pressing all the buttons. I'm thinking I got an "out of box failure".
  16. Feb 7, 2010 at 7:06 PM
    centraltextaco
    centraltextaco Active Member
    Harker Heights
    Prerunner
    treat it just like a tacoma, ignore the problem, remain loyal and be very very paitent with the manufactor, nevermind you spent good money on the product.
  17. Feb 7, 2010 at 7:11 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Get back to the other thread :p
  18. Feb 7, 2010 at 8:35 PM
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
    "4)
    Turn the vehicle on. If it can be run, start it. If it can’t be run, turn the key to the “run” position. This is the position it is normally in
    when the vehicle is being driven.
    5)
    Plug the ScanGaugeII Plug into the OBDII socket. The ScanGaugeII derives all the power it needs from the OBDII connector. No other connections are needed for its operation. Wait for the ScanGaugeII to Connect.
    NOTE
    : If it does not stop saying "Connecting..." or the screen goes blank after 60 seconds, refer to “TROUBLESHOOTING” on page 24 and 25."
    You can download a PDF file of the manual here: http://www.3n1autocomputer.com/support/
    Good Luck,
    Yuma Taco,
  19. Feb 9, 2010 at 8:30 AM
    Linear Logic LLC
    Linear Logic LLC Member
    Hi saf023,
    There is a ribbon cable that connects the display to the circuit board of the ScanGauge that can sometimes become loose causing the display to no longer display data. The backlight will still work since it pulls it's power from pins separate from the ribbon cable.
    Send an E-mail to service@linear-logic.com describing your problem (or just quoting your original post and this response) or call us at 1-888-433-5664 and we can get you set up with a new unit that should work properly.
    Sorry about your unit not working initially, I know how frustrating that can be.
    James DeLong
    Linear Logic LLC
  20. Feb 11, 2010 at 6:16 PM
    saf023
    East Coast
    I still don't have a working ScanGuage and I'm none too happy about it.
    I got a second email from their customer (no) service who said they will ship a replacement today. That's basicially what the last email said on the 7th of February.
