Bought a used Tacoma - What next?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by birry, Apr 29, 2013.
  1. Apr 30, 2013 at 7:56 AM
    birry
    birry [OP] Well-Known Member
    Oklahoma City, OK
    2008 4x4 DCSB
    OME 885, Bilstein 5100's, Wheeler's (single) AAL
    I know there are pages and pages of discussion on this, but with my truck being at 100k miles, should I do a drain/fill or a full flush of the tranny? I'm a little intimidated by the cost/time/process of the full flush, especially with my limited garage space.
  2. Apr 30, 2013 at 4:36 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    My full drain used up something like 11 qt of fluid. The entire affair cost me a little over $200. Not worth the DIY. Ask around at good shops.
  3. Apr 30, 2013 at 4:43 PM
    WTFaulkner
    WTFaulkner Well-Known Member
    Kris
    SLC
    Tacoma
    Stuff
  4. Apr 30, 2013 at 5:22 PM
    slingn em
    slingn em Member
    bradley
    mississippi coast
    05 TRD SPORT
    bull bar, magnaflow exhaust, k&n drop in,
    I just performed a general tune up on my 05 4x4 auto. I did front and rear diff fluid, transfer case fluid, flushed the transmission with 15 qts of the toyota ws trans fluid. Throttle body and maf sensor cleaning, and new spark plugs. I used this forum to gather information on each of those and found everything I needed. The tranny flush isn't bad at all. I would recommend getting a buddy to help so you don't have to crawl from under truck to cab so many times. I talked my local dealer down to $7 a quart for the toyota ws auto tranny fluid. I also took the extra time to drop my tranny pan and clean before flushing. So I got a new gasket from dealer for that. I plan on doing a coolant flush soon and have the bushing ordered for the front cv axle vibe issue. Also ordered ride rite air bags and an on board air compressor to help that rear suspension under light loads. All things I would give attention to if I were you.
  5. Apr 30, 2013 at 5:33 PM
    toyotaman29
    toyotaman29 Well-Known Member
    Darrell
    North Carolina
    2021 SR Prerunner Silver
    LED upgrades, Husky weatherbeaters, Black 16’’ wheels
    You will need a grease gun and there should be 3 fittings on the front drive shaft and 2 on the rear one, i grease mine every 5 to 8 K miles.
  6. May 1, 2013 at 4:53 AM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    I might do a drain/fill and check the fluid condition to see if it needs a full flush.
  7. May 8, 2013 at 9:18 PM
    nizzmont
    nizzmont Well-Known Member
    Brian
    S.E WA state
    2015 doublecab TRD sport
    in progress
    congrats on the truck!i just picked up my 08 double cab this past friday,24900 miles on mine.for your tranny i would honestly take it to a shop that does a pan drop and filter change.my close friends own a shop and its well worth it to see whats going on in there and you may catch something before its turns worse.just my thoughts on it
