Bought some axles...sas coming soon
Discussion in 'Solid Axle Suspension' started by dtmccray, Apr 15, 2012.
  1. Oct 15, 2012 at 6:49 PM
    #81
    alove0750
    alove0750 Well-Known Member
    Adam
    Concord, NC
    2015 DCSB 4x4
    Icon coilovers, shocks and springs SPC Upper Control Arms SCS Ray 10’s w/ 265/70R17 BFG KO2’s Leer 100XR shell
    I'm running 3 inches of up travel and 9 inches down. It's worked pretty good for me so far. I have zero clearance issues which makes things nice :rolleyes:
  2. Oct 15, 2012 at 7:34 PM
    #82
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Most CO suspension usually run at least 4-6" up travel and 12-10" downtravel. But most are 16" CO's since they are stupidly expensive mid as well go big or go home.
    What size CO's are you using?
  3. Oct 16, 2012 at 7:23 AM
    #83
    dtmccray
    dtmccray [OP] Well-Known Member
    millbrook alabama
    01 money pit
    d60 3link sas, bumpers, sliders, arb twin on board air comp w/11gal air tank,38.5/14.5r15 tsl sx swampers, rock 8 beadlocks, detroit rear, trutrac front.
    12 inch CO's
  4. Oct 16, 2012 at 6:26 PM
    #84
    Supra TT
    Eric
    Indiana
    I'd say 4" up travel will be perfect.
  5. Nov 10, 2012 at 7:13 PM
    #85
    dtmccray
    millbrook alabama
    01 money pit
    Almost done...still got to get the brakes, ps lines, fab skid for the radiator, fab a belly pan , wire up the winch.....shit I'm never going to finish this thing.
  6. Nov 10, 2012 at 7:31 PM
    #86
    dtmccray
    millbrook alabama
    01 money pit
    I ended up going with the FROR cross member. It seems well built and fit pretty well. I raised the rear of the transfer case as much as I could so the top of the cross member hit the floor pan. I used a hammer pry bar and a long punch to clearance around it. I had to cut my exhaust hanger out of the way to install it so I welded part of the bracket to the cross member so I would have a support in that area. The only problem I had was the ds mount was about a half inch too short so I made a new one.
  7. Nov 10, 2012 at 8:07 PM
    #87
    dtmccray
    millbrook alabama
    01 money pit
    A few pics of how the pinch weld looks under all the plastic.
  8. Nov 10, 2012 at 8:14 PM
    #88
    dtmccray
    millbrook alabama
    01 money pit
    This part hurt...cutting on a new elite bumper...gotta make room though.
  9. Nov 10, 2012 at 8:19 PM
    #89
    dtmccray
    millbrook alabama
    01 money pit
    Bye bye flares. Needed more room. Still haven't trimmed the rear yet.
  10. Nov 10, 2012 at 8:27 PM
    #90
    dtmccray
    millbrook alabama
    01 money pit
    End result 38x15.5r15's fit... more or less. I think I cut a little more than I needed to on the fenders but the flares made such a nice guide.... I though I had a few pics after I cut the fenders but, I guess I did that after the camera died. I'll get some more later. Now I'm trying to find brake and ps lines.
  11. Nov 15, 2012 at 4:11 PM
    #91
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
  12. Nov 16, 2012 at 5:07 PM
    #92
    Supra TT
    Eric
    Indiana
    Looks good Dtm. Is that at full stuff?
    Also it looks as if you placed the shock tower bracket way far back towards the firewall, It looks to me like there is quite an angle on that shock. You should of angled it so you aren't using the misalignment heims as much... But too late now.
  13. Nov 16, 2012 at 7:56 PM
    #93
    dtmccray
    millbrook alabama
    01 money pit
    The shock is where all pro said to put it. I don't like the way the junk they sent me works the lowers are too far out on the axle and it limits tire size. Too late now. As far as whether its at full stuff or not, I'm not sure I didn't check it with the shock in place but it should be close.
  14. Nov 16, 2012 at 8:04 PM
    #94
    Supra TT
    Eric
    Indiana
    I am loving the bigger pictures too man!! Much better!
    You could always cut down the links to make the front in closer to the firewall. Though, that would potentially lessen suspension travel/binding. I cannot believe that they have the shock tower instructed to put back so far, yet the axle is completely pushed the other direction.
  15. Nov 16, 2012 at 8:07 PM
    #95
    dtmccray
    millbrook alabama
    01 money pit
    I have some adjustment on the links when I have it alligned I'm going to pull the axle back about an inch or so.
  16. Nov 16, 2012 at 8:10 PM
    #96
    Supra TT
    Eric
    Indiana
    You ever get your brake lines and ps lines? I recommended a company in the other thread.
  17. Nov 16, 2012 at 8:33 PM
    #97
    dtmccray
    millbrook alabama
    01 money pit
    I found a local company that will make the steering lines. For the brakes I'm off tomorrow and I'm going to cut my hard lines and put standard fittings on the ends away from the master cylinder. Then I'll l just have to buy the actual lines for the front that go on the calipers. The axels have standard fittings on them. I also have to plumb aproportioning valve into one. of the .
  18. Nov 29, 2012 at 7:57 PM
    #98
    dtmccray
    millbrook alabama
    01 money pit
    Got all my brake parts in finally. Going next tues or wed to get my ps lines made then I will be more or less done...sort of. Tires and wheels should be here either this week or next. I bought a supercharger for it but I'm going to run it for a couple of weeks before I start on that. Still gotta go pick up some plate for the belly pan. It's getting close to being useable though.
  19. Dec 8, 2012 at 5:59 AM
    #99
    dtmccray
    millbrook alabama
    01 money pit
    Waiting on one -3an tee fitting to finish my brakes. Wheels are sitting under the kitchen table. Supercharger in the living room floor. Tires shipped yesterday. It's getting close to being driveable. Still gotta figure out how to get my e-brake tied in,skids,mount and wire up winch solenoid,.....I'm never going to finish this thing.
  20. Jan 8, 2013 at 7:46 PM
    #100
    dtmccray
    millbrook alabama
    01 money pit
    Not much change got my tires in. Been working on my brakes they are leaking all over the damn place....it's just been one thing after another...
