Bought Tacoma with no Key Fobs
Discussion in 'Technical Chat' started by LMR, Oct 11, 2011.
  1. Oct 11, 2011 at 10:44 AM
    LMR
    LMR [OP] GO JETS GO
    Lee
    In The True North
    2008 Tacoma DCSB TRD
    Shorty antenna, Weathertech digital fit, tonneau cover
    I recently bought an 08 Tacoma Double cab short box, but it only came with one key and no key fobs. I live in Canada, but the Truck was imported for the United States. Toyota dealership quoted me $214 for each key fob and $50 for a chipped key. Also $40 to program each fob.
    Could someone tell me a cheaper way to get a couple key fobs? eBay perhaps? Thank you..
  2. Oct 11, 2011 at 7:18 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I only got one remote with mine. Have not bought a new one yet, but have seen them on Ebay for cheap, used. There is a programming procedure in the owner's manual for the remotes.
    The keys are not owner programable like the remotes. Some members on here have said you can get keys cut and programmed at ACE hardware. I wound up buying factory Toyota keys on Ebay from Franke Toyota in San Diego for about half what the local dealer wanted. I then got them cut at the local locksmith and took the truck to the dealer for programming. The programming was a half hour of labor. Get as many spares as you think you will need and get them all done at once so you only pay that programming fee one time.
    If they only want 50 bucks for the key programmed, that's a deal! The remotes are way too high, and there is no need to pay for the programming. If I am reading your post right, sounds like you should have the dealer do the key from start to finish and go on your own for the remotes.
  3. Oct 11, 2011 at 7:21 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    You can definitely find the remotes themselves for cheap online, used of course. Programming the remotes is easy; as Joe said, the instructions are all over the place on the web.
    To my knowledge, our keys do not have immobilizer chips in them. I had two spare keys for my 2007 that were just your standard metal keys that you can get at Lowe's for a few bucks, or at the dealership for a little more.
    Fink
  4. Oct 11, 2011 at 7:26 PM
    enjm10
    enjm10 Well-Known Member
    Eric
    NM
    07 V6 4x4 Silver Streak
    20% tint all around, 5100s all four corners w rear aal, step bars, windshield visors, foglight anytime mod, front black lip, door emblems blacked out, satoshi grill, avid light bar, dash light mod blue, also did my own stereo led mod
    I too need a remote n key when I bought my truck it only came with one key n remote I thought bout buying a cheap remote on eBay and programming it this way if I accidentally lock my keys in my truck I have an extra remote to unlock it instead of asking for use of a slim Jim which wont work anyway
  5. Oct 11, 2011 at 7:26 PM
    cheehab
    cheehab I bleed Black and Gold
    Adam
    Winter Park, CO
    2015 Tundra TRD Pro CrewMax
    I've bought some fobs from eBay before- several for a Subaru and one for my Tacoma. They send directions and programming takes just a minute to do. Freeprogramremotes is the eBay store I've used. Would definitely do it again. Dealership prices are ridiculous.
  6. Oct 11, 2011 at 7:28 PM
    enjm10
    Eric
    NM
    Is it a standard price normally to get the keys programmed at a dealership after being cut at say Lowes or ace?
  7. Oct 11, 2011 at 7:34 PM
    Fink
    Orlando, FL
    Again, to my knowledge, you don't need to get the actual keys programmed. The only thing you need to get programmed is the remote, and this is free if yo use the instructions that are all over the web.
    Fink
  8. Oct 11, 2011 at 8:14 PM
    enjm10
    Eric
    NM
    Hmmm myb ill ask ace to cut me a key anyway n try it (nonprogrammed key) if not what should I be worried bout what's $5 or whatever it is.
  9. Oct 11, 2011 at 10:20 PM
    joes06tacoma
    Joe
    Central Coast, CA
    My 2006 v6 has chipped keys for sure. I had the keys cut and then tried to start the truck and it would not start till I had the keys programmed.
    I have the flashing "car with a key in it" under the radio. It's my understanding that if you have that light you have chipped keys. My company truck does not have the light (09 4cyl) and I have a standard metal key that starts the truck.
  10. Oct 11, 2011 at 10:22 PM
    Manwithoutaplan
    ID
  11. Oct 11, 2011 at 10:24 PM
    joes06tacoma
    Joe
    Central Coast, CA
    My dealer charges a half hour labor to program any number of keys all at once. The ECU only has space for a certain number of keys. If there are lost keys taking up space in the memory and they need to clear the ECU memory and start over, then they charge a full hour's labor. They have to "call the mothership" to wipe the ECU's key memory and start from scratch.:eek: You might want that done anyway if you bought used and are concerned about other keys floating around.
  12. Oct 11, 2011 at 10:25 PM
    Manwithoutaplan
    ID
    how about them jets huh???
  13. Oct 12, 2011 at 5:25 AM
    LMR
    LMR [OP] GO JETS GO
    Lee
    In The True North
    Actually, I live in Winnipeg and went to the Jets home opener. Awesome!!
    Thanks for the help guys, I will buy a fob from eBay and program it myself. I'm pretty sure I have the chipped key because I also have the car with the key in it flashing under my radio.
  14. Oct 12, 2011 at 7:45 AM
    Fink
    Orlando, FL
    My 2007 had that light and I could use the cheapo $8 keys (rubbery top, metal teeth) form the dealership and they were never programmed.
    Weird.
    Fink
  15. Oct 12, 2011 at 9:33 AM
    enjm10
    Eric
    NM
    I have the light w a key on it too I believe ill have to check n then I guess c bout ordering a cheaper key off eBay have it cut then take it to get programmed.
  16. Oct 12, 2011 at 9:34 AM
    enjm10
    Eric
    NM
    I still am gonna try cause I believe u I just hope it works on my truck lol save me some cash
  17. Oct 12, 2011 at 9:37 AM
    Fink
    Orlando, FL
    I'm glad - definitely let us know the outcome.
    I'm curious to see if my memory is as bad as it seems it may be. :D
    Fink
  18. Oct 12, 2011 at 9:40 AM
    enjm10
    Eric
    NM
    Memory u ain't much older than me, well nevermind I guess I could c where ur coming from but mine was :rasta: lol
  19. Oct 12, 2011 at 9:41 AM
    Fink
    Orlando, FL
    :laugh:
    Fink
  20. Oct 12, 2011 at 9:46 AM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    i dont know if anyone posted, but www.ekeylessremotes.com ....then take your key to get it cut at a local hardware store... then just take the key and the fob to get it reprogrammed by a dealer... tell them that your key fob and stuff suddenly stopped working.. they should do it for free ....if they are nice..
    they did mine when i took my truck in for the scheduled maintenance
