Bought TRD Pro but got TX Baja Suspension, BUT wait... it gets shadier
Discussion in 'Suspension' started by Navy Jumper, Feb 28, 2018.
  1. Feb 28, 2018 at 10:26 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Yeah that's bull shit. That guy needs to be reported to eBay STAT. So nobody else gets screwed. Fine to sell if he explains the situation and gives you some confidence. But this was a blatant attempt at misleading someone into thinking they're getting something they're not.
  2. Feb 28, 2018 at 10:30 PM
    NMTrailRider
    New Mexico
    And offering to pay to get them shipped back... he's just trying to not blow his cover. Keep you happy so he can con the next guy.
    Just imagine if I went onto the TW buy/sell page... selling a brand new Pro suspension. With pictures! And then I send you a Baja kit with the labels cut off the shocks and the boxes?
    There'd be some head scratching. And then the mob would soon follow.
  3. Mar 1, 2018 at 1:23 AM
    JS760
    JS760 Well-Known Member
    San Diego
    2017 DC Sport
    Put the pitchforks away guys
    Seller has 25k feedback and has sells hundreds of auto parts a day
    He’s not deliberately trying to pull anything over on anyone
    Like someone said, ebay will auto populat part numbers depending on how you process your listing..it’s happened to me.
    Also it’s CLEARLY a Baja kit in the picture since it’s not assembled.
    And he offered a return.
    Was the item not as described? Technically
    Was the item not in the condition described? Maybe, if stickers are important to you.
    The shadiest part about the whole thing is the OP only posting one side of the convo. What are you hiding.
    And then there’s this from the listing
  4. Mar 1, 2018 at 1:34 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    They're probably a returned part. If i was the seller, i would be happy to take them back. Arn't these on national backorder now, if so i would relist for more than before.
  5. Mar 1, 2018 at 1:55 AM
    Navy Jumper
    Navy Jumper [OP] Airborne Paratrooper
    sigh.... really man? I have nothing to hide.
    I got my shipment, opened it up and saw it wasn't the right PN.
    Here's the sequence of events.
  6. Mar 1, 2018 at 11:34 AM
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    So for what it's worth, my TRD Baja suspension, purchased from Toyota, is branded as TRD/Toyota and all that jazz. That said, I don't think OP really got ripped off and got fakes, the parts and stampings look correct.
    I agree with the other person on this thread that commented they are likely over stock being sold off by Bilstein without Toyota/TRD branding to remove them from any warranty or future part dispute. Likely part of some agreement between the two companies.
    To OP, looks legit man. I wouldn't sweat it honestly. Yea the removal of the branding is weird but you have the real parts.
    Navy Jumper[OP] likes this.
  7. Mar 1, 2018 at 2:41 PM
    presta24
    presta24 Well-Known Member
    chris
    Cincinnati
    2014 Taco TRD 6spd, 2k3 SR5 4runner V8
    Scratches, dents, lots of squeaks.
    Talked very briefly to my sister's bf who works at the bikstien plant here in Cincy. He said the shocks were definatly made at his plant. The sticker that was cut off the boxes is what Toyota outs in them. That's all the info I got he got a call at work
    oscolivar1 and Navy Jumper[OP] like this.
  8. Mar 1, 2018 at 4:21 PM
    NMTrailRider
    New Mexico
    The seller just isn't listening to you. I think he believes what he's telling you is correct (and maybe not intentionally misleading you, giving him the benefit of the doubt). And he maybe isn't aware of the Pro vs Baja. He thinks they're the same thing. He's just not paying attention.
    That said, he's not giving up details of the back story, either (cut labels, etc).
  9. Mar 2, 2018 at 4:58 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Agreed that the OP has the real parts.
    As others mentioned the picture in the listing shows Baja; as the shocks are not assembled, the rear remote shocks have braided lines and it has the short bump stop kit. Why the branding is removed is odd and we can only speculate.
    OP you did get a killer deal this setup being it goes for over $1400, which is about what I paid for mine.
    http://trdparts4u.toyotaofdallas.com/scripts/prodView.asp?idproduct=-10512
    Deal or not, when I buy something for my truck I buy it because I did my research and wanted something very specific so if I got something else I would send it back.
    However if you are unfamiliar with the differences in the Baja kit vs the Pro kit, here they are:
    Baja
    -650lb coils
    -Digressive shock valving
    -Extended travel front bump stops (extends compression)
    -Raw aluminum shock bodies
    -Stainless braided rear reservoir line
    -Rear brake line drop bracket
    Pro
    -600lb coils
    -Progressive shock valving
    -No extended travel front bump stops (does not have extended compression)
    -Zinc coated aluminum shock bodies (prevents discoloration due to surface corrosion)
    -Rubber coatedrear reservoir line
    -Rear brake line drop bracket (I believe, same as Baja)
    The big difference is in the first 2 items, spring rates and digressive vs progressive shock valving leading to very different driving experiences.
    This chart is clearly bias, but it has some good notations for digressive vs progressive dampening curves.
    The digressive 'supportive areas' on the chart is going to lead to a firmer sportier feel in the Baja whereas the progressive 'mushy areas' are going to be a softer feel on the Pro. There are of course pros and cons, Toyota used a progressive shock for a reason. Many small repetitive bumps like a washboard or lower speed off road trail will be much smoother on a progressive shock like the Pro whereas the Baja with the steeper initial digressive curve is going to transfer more of those shocks to the chassis, resulting in a harsher off road ride in these conditions. However, it is that steeper initial digressive curve that helps give a sportier handling response on the street.
    In choosing whether to keep or send back, I'd look at the above info, how you use your truck and determine what is best for you. Both kits offer the same gain in ground clearance. For me, I optimized my suspension for how I use my truck the most. It sees the trails a couple times a year, and the street nearly every day. So I went with the Baja.
    BizzyB726, JustDSM, Nateclimb and 7 others like this.
  10. Mar 3, 2018 at 5:21 AM
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    You sure the Pro kit is progressive? This is the first I’ve heard this. I thought all the Bilstein stuff (5100, 6112, Baja, Pro) were all digressive. The new Fox stuff on the 3rd gen Pro is progressive I believe. Also internal bypass.
  11. Mar 3, 2018 at 6:02 AM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Good info!:thumbsup:
  12. Mar 3, 2018 at 7:18 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Pro is listed as 3-stage progressive:
    http://www.fourwheeler.com/vehicle-...-series-truck-and-suv-line-up-o-e-s-off-road/
    Hmm, but here the Tundra Pro is specifically listed as progressive but not the Tacoma:
    https://www.superiortoyotapa.com/blog/2014/february/7/toyota-trd-pro-off-road-package.htm
    Maybe it is just the Tundra, Toyota’s press release is here and it says Progressive for the Pro Tundra:
    https://www.autoblog.com/amp/2014/02/06/toyota-trd-pro-series-tundra-4-runner-tacoma-chicago-2014/
    BortisYeltzen[QUOTED] likes this.
  13. Mar 3, 2018 at 10:58 AM
    scollins
    scollins Well-Known Member
    Scott
    Renton WA
    2019 Ford F450 STX 6.7L Powerstroke
  14. Mar 4, 2018 at 5:57 PM
    Navy Jumper
    You know what I just noticed in my pics?
    Look closely at the rings around them. One is on the upper ring, the other is on the lower. What's that about?
  15. Mar 4, 2018 at 6:04 PM
    #35
    Hawco636
    Hawco636 Great White North
    2010 MGM SR5 - V6 Manual
    @Navy Jumper Those rings are set up to account for taco lean. The strut with the higher set ring goes on the driver side
  16. Mar 4, 2018 at 6:05 PM
    #36
    Navy Jumper
    Ahhhh :thumbsup:
    TACOVRD likes this.
  17. Mar 4, 2018 at 7:29 PM
    #37
    NMTrailRider
    New Mexico
    Still listed at a lot of places, but most (all?) places are out of stock. And nobody seems to know if stock will be replenished. There are multiple threads on the forum about this suspension being liquidated. Some of us got it for as low as $500's. Most around $600's. Lots of forum members installing in the last couple of weeks. Stay tuned.
  18. Mar 10, 2018 at 10:13 AM
    #38
    CanOfRockstar
    CanOfRockstar Active Member
    2012 Barcelona Red TX Pro
    The only difference between the two is that the Baja kit has a higher compression rate, I personally looking to get a baja kit over a pro kit for that reason.
  19. Mar 10, 2018 at 10:14 AM
    #39
    CanOfRockstar
    compression rate is the only difference
  20. Mar 10, 2018 at 10:25 AM
    #40
    NMTrailRider
    New Mexico
    Also- the Pro has rubber coated lines on the resi's and a zinc coating on the shocks to prevent accelerated corrosion issues.
