Bought used 1998 Talcoma 2.7 4x4 ext cab
Discussion in 'New Members' started by Richandtd, Jan 19, 2021.
  1. Jan 19, 2021 at 11:57 AM
    Richandtd
    Richandtd [OP] New Member
    Richard
    1998 dark green Talcoma 4x4 extended cab extra leaf in both sides rear spring packs
    Back in 1999 I bought it with about 20k miles on it. Within the first year had a aluminum cap made for it. Since the cap was a contractor one with about 12” higher than the roof it was heavy and the truck leaned too much in corners so I went to a spring shop and had 1 extra leaf added to each rear spring pack. Made all the difference in the world. Last year I went over 200k miles and the engine check light would come on for a while was told it was a vacuum leak not to worry. So I kept driving it and ran it low on oil my fault. Currently it is at a shop having the engine removed and brought to a machine shop for a complete overhaul. Was told by the shop doing removal that proper break in will be to change the oil at 500 miles then again at 500 miles then put normal oil changes.
  2. Jan 19, 2021 at 11:58 AM
    Bigdaddy4760
    Maner
    Poolville Texas
  3. Jan 19, 2021 at 11:59 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Welcome to The Forum! :thumbsup:
  4. Jan 19, 2021 at 12:01 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Welcome to TW, Richard! :cheers:
  5. Jan 19, 2021 at 12:15 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Hello Richard
    Welcome to TacomaWorld
    buckhuntin-tacoma likes this.
  6. Jan 19, 2021 at 2:03 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  7. Jan 20, 2021 at 12:41 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  8. Mar 22, 2021 at 5:10 PM
    Richandtd
    Richard
    Ok I have my 98 Talcoma back running great did my first oil change at 500 miles and today the check engine light came on. Went to Auto parts store and ran the code checker and P0120 Throttle/Pedal Position Sensor A Circuit is showing. They had the Sensor in stock so I bought it. I see where it is and it will be tight but doable. When I started the truck to leave with my new Sensor in my hand so I can change when the engine is cooler and the check engine light is no longer on. I still plan on changing it and when I do will I need to clean any possible carbon from the mounting hole? And does anything else need to be done after replacing?
