Bounce when braking
Discussion in '1st Gen. Tacomas (1995-2004)' started by VintageFast, Jan 21, 2014.
  1. Jan 21, 2014 at 12:35 PM
    VintageFast
    VintageFast [OP] Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Ok. So I have a stock suspension '02 DBL cab. When slowing for traffic on the freeway or exiting, etc. Between 50 and 40 mph my truck seems to bounce from what I think is the rear. If I'm coming down for a panic stop it's a hard bounce. Shocks are good with only about 30k on them and it did it before I replaced the shocks, Leafs are stock with almost 350K on them. The steering whell is not affected by the bounce. Rear drums out of round? I've never done a rear brake job on this truck since I bought it new.
  2. Jan 21, 2014 at 12:46 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Need more information.....
    This only occurs while braking? What exactly is 'bouncing'??
    Are you saying the rear of the truck is 'bouncing' up & down and shifting sideways?
    Or are you saying you're feeling a 'thump'?
    Does this happen ALL THE TIME while braking? Only when you first brake? Let off the brakes?
    What happens if you just let off the gas (and no brake)?
  3. Jan 22, 2014 at 7:29 AM
    VintageFast
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Only when braking.
    Seems like the rear is bouncing up and down. No sideways action.
    Only happens when braking and only happens between 40 and 50 mph.
    If I let of the gas and coast, it is a very slight bounce (almost like a vibration)
  4. Jan 22, 2014 at 8:32 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Try lubing the rear drive shaft (all zerks).
    Also, carefully inspect the rear leaf springs, one of them could have snapped, causing excessive axle-wrap when braking.
  5. Jan 22, 2014 at 9:04 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    350K?,,Rear drums/brakes due for service. That's your starting point. Once whatever shop does the work and the cutting tip on the drum lathe starts to take metal,,it will cut then skip a bare patch,,then cut again. This is the best way to show a warped drum. At 350K, it's probably due for some new brake components back there.
    I have 208K on my rear drums,,original pads still look like new and no pulse when stopping.
  6. Jan 22, 2014 at 6:24 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Those leaf springs are running on borrowed time
