Bouncy and interval shaking when I drive
Discussion in '1st Gen. Tacomas (1995-2004)' started by Swivot, Aug 26, 2017.
  1. Aug 26, 2017 at 7:09 AM
    Swivot
    Swivot [OP] Well-Known Member
    I have a 2001 Tacoma v6 4 by 4. I noticed yesterday that when I drive their is this slight shaking and bounce if feels like in the rear of my vehicle. It is starting to get real annoying. My truck isn't driving as smooth as it used to be. How do I tell or diagnose the problem further? Could it be my struts or rear shocks? Thanks guys...
  2. Aug 26, 2017 at 7:28 AM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    Could be your tires...
    wilcam47 likes this.
  3. Aug 26, 2017 at 7:32 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    check tires for missing tread or bulged out/separated treads. Look at the circumference and see if it looks round if theres a higher spot it could be internally separated. Also get your wheels balanced.
  4. Aug 26, 2017 at 9:50 AM
    Swivot
    Ok I will go to discount tire today and have them take a look. I just bought new tires a month ago, but hopefully its something easy that is still under warranty. Just hoping its not an expensive fix.
  5. Aug 27, 2017 at 3:12 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I managed to knock a wheel weight off .
    Just the one little weight caused the truck to shake so much I thought all the lugs were loose.
    That also caused the tire to cup really bad till I got home around 100 miles
    I have also hit stretches of roads just resurfaced that are rough enough I think the wheels are falling off to the point I pull over and inspect things
  6. Aug 27, 2017 at 7:28 AM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    I just found a BF Goodrich that was out of round. Replaced it and all is smooth again. It took forever to diagnose though. I balanced them all multiple times. Replaced u joints, tie rod ends, ball joints, rack bushings. I was so relieved when I finally found it, I didn't even care that the tire was bad.
  7. Aug 27, 2017 at 7:38 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Hmmm I swear I have a KM2 that might be. I have been having discount rotate/rebalance every 3-6k but I still have a shake even though I have new shocks front and rear, new TRE, new rack
  8. Aug 27, 2017 at 7:50 AM
    toyotamd
    toyotamd Well-Known Member
    Arizona
    2002 Xtra Cab V6 auto TRD
    definitely sounds like a balance/alignment issue. did you figure it out?
  9. Aug 27, 2017 at 8:19 AM
    preybird1
    preybird1 02 taco on 37's
    Russ
    Salt lake city Utah
    2002 taco s\c
    Trd S\C with nosecone hybrid bearing upgrade kit. 2.0 urd pulley, 7th injector kit-urd "6 fabtech lift with 3" body lift. 20" XD spy wheels with toyo open country r\t's in 37"x 12.50x20. Front and rear diffs re-geared to 4.88 dirty 30 drive axles. and a rhino pack clutch. Custom exhaust and huge mudflaps!
    That's all rear shocks and if the tire(s) is (GOOD) ie not a lot of weight needed to balance the first time then you can prove it's a shock. If its more than 1.5 oz of weight can be a defect tire and will have balance issues its whole life. Get in the truck and go around a paved turn at higher speed and make sure it has bumps. if the rear end starts to bounce and moves to the side like 6"-1' and doesn't trac exactly as the front tires then the shock is worn out and is actually unsafe. In fact if you have over 50K miles you should buy new shocks period! Also stay away from discount tires they do no mechanical work or alignments but they want to tell whats wrong with the vehicles. They are idiots and give real shops a bad name. sure you get rubber cheap but you can price match any competitor and most real tire shops have alignment racks and mechanics. Not wall-mart, not Costco, not discount tire. Shop wisely and avoid aforementioned retailers for auto anything.........also jiffy lube is trying to get into tires and auto repairs like brakes now LOL amateurs.
  10. Aug 27, 2017 at 8:30 AM
    preybird1
    Russ
    Salt lake city Utah
    2002 taco s\c
    I sell tires for a living and have for 12yrs now. B.F. goodrichs are notorious for balance issues. When you guys go into have the work done ask if they will allow you to watch them balance the tires. And see what weight the machine is calling for and document each tire position and weight called for and compare the tires numbers. if one is out of weight by more than 2 oz. I send it back to the warehouse and get another. If i don't that customer will be in way to much for balance issues because the tire is defective. A little secret if discounttires wont help you ask for a b.f. goodrich-michelin-uniroyal adjustment form call the number on the back and make a claim with michelin about the tires and they will do something about it! It's a huge PITA for the tire associate but they don't lose out either as the manufacturer gets the old tires back to test them for rapid wear or blemishes and defects and credits the business for any lost retail amount. Avoid places like discount that cannot even replace a wheel stud if it breaks or properly align a vehicle because alignments DO NOT SHAKE or have anything to do with vibration! You could have bad tie rods that can cause a shake in the front but that is not alignment sorry.
    Dalandser and PROseur like this.
  11. Aug 27, 2017 at 9:05 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I used to go to discount tires for the great prices. But they kept cross threading the lug nuts on the studs and have to break the stud to get the wheel off to balance. Plus since they don't do any mechanical work there, I'd get sent to a wheel & brake shop to have them replace the stud. Sure it was free but not really because your time isn't free. Whereas if you went to other tire shops that do everything in house, like I do now. It gets done right away. But I haven't had a problem since leaving discount tires. But that's how they can offer the tires for a cheaper price. Lower overhead since they only have to hire people that can take tires off, balance them and put them back on.
  12. Aug 27, 2017 at 3:34 PM
    wilcam47
    Will
    Bourbon state
    glad its fixed
  13. Aug 27, 2017 at 6:43 PM
    Glamisman
    Glamisman Well-Known Member
    when I had to do tires I would loosen the locking cone on the balancer and rotate the tire 90 degress then lock it in and spin her up again just to check. Quick and simple.
  14. Sep 9, 2017 at 11:42 PM
    Swivot
  15. Sep 9, 2017 at 11:44 PM
    Swivot
    Thanks guys, So the shaking mellowed out and its not as bad anymore. I had my shocks tested and they look overdue to be changed. I am going to save up and get those 4 shocks replaced. And hopefully that will just make my truck a smoother ride. Am planning on getting OEM TRD shocks from my toyota dealer. Think thats the right call for new shocks? I got offroad every once in a while...
  16. Sep 10, 2017 at 7:45 AM
    twblanset
    Todd
    Vacaville, CA
    2015 TRD OR
    Where are you located? If you're near me, I have some used Bilsteins you can have if you want. I'm in the SF Bay Area.
  17. Sep 10, 2017 at 6:01 PM
    043RZ
    043RZ Well-Known Member
    Spring Grove, PA
    2004 Tacoma SR5
    6" Fabtech Lift, OME Dakar leaf springs, BudBuilt Traction Bar, 15" American Racing Wheels, 5.29 Nitro Gears, 35" BFGs AT, Pioneer 200 Watt Stereo, 6x8 Pioneer speakers, Raised Front and Rear Diff Breathers, Deck Plate Mod, Red Interior Underglow, Red Exterior Underglow, Cool White LED Rock Lights,
    Hey OP. Let me know if replacing the shocks eliminates the tire bounce. I'm having a similar issue that's only present in the rear of my truck. No matter what orientation I put my tires, I still get a bounce in the rear
