Bouncy ride
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08tacorunner, Jan 11, 2018.
  1. Jan 11, 2018 at 5:47 PM
    08tacorunner
    08tacorunner [OP] Member
    08 Tacoma PreRunner
    08 PreRunner 4 inch lift 33 inch tires 16 inch rims I feel every bump in the road can get very annoying at times any pointers on a smoother ride I usually come here and read through some things and it's very helpful
  2. Jan 11, 2018 at 5:49 PM
    11Bguy
    11Bguy Well-Known Member
    Va
    2017 DCSB TRD
    Icons/ JBA UCA's
    did it start after you lifted it? What lift do you have?
  3. Jan 11, 2018 at 5:51 PM
    08tacorunner
    08 Tacoma PreRunner
    Yes I feel like it got worse rough country simple cheap. My buddy has the same thing and his rides smooth.
  4. Jan 11, 2018 at 5:54 PM
    11Bguy
    Va
    2017 DCSB TRD
    Icons/ JBA UCA's
    Do you know the spring rate on the front? Do you have a front bumper?
  5. Jan 11, 2018 at 5:54 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Recommend you look at apples to apples match up with your buddy’s setup. Same lift, same settings, no leaks from suspension or broken coils/spindle. Are you running e rated tires? What air pressure?
  6. Jan 11, 2018 at 5:55 PM
    11Bguy
    Va
    2017 DCSB TRD
    Icons/ JBA UCA's
    ^this
  7. Jan 11, 2018 at 6:02 PM
    08tacorunner
    08 Tacoma PreRunner
    Yes I have E rated tires BF Goodrich KO2 AT and I'm only running 30 psi
  8. Jan 11, 2018 at 6:07 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    It is somewhat relative when you say bouncy but e rated 10 ply tires aren’t very soft or flexible and somewhat over rated for our trucks. You could play with the PSI some and see if that helps. I run less in the rear when not hauling or towing. About 4 psi less. Does your buddy have the same tires? What about everything else? Same rated coils? That is typically the biggest culprit.
    llamasmurf likes this.
  9. Jan 11, 2018 at 6:36 PM
    Pigpen
    Dan
    Northwest Montana
    I run 40 psi in my load E 33s. I feel like they ride nice and smooth. Might be my suspension. I put money into my lift. Rough Country is known for a rough ride.
  10. Jan 11, 2018 at 7:23 PM
    08tacorunner
    08 Tacoma PreRunner
    Yah I've been looking at different kits. No not the same tires he has 6 ply MT tires. Same exact lift almost the same exact truck that's why I'm so confused I'll play with the PSI see what happens
  11. Jan 11, 2018 at 7:28 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    C rated 6 ply make a huge difference. The PSI will help some but will only get you so far.
  12. Jan 11, 2018 at 7:29 PM
    Pigpen
    Dan
    Northwest Montana
    Does your friend happen to have a TRD Offroad?
    The Offroad has different coil springs than the other models.
  13. Jan 11, 2018 at 7:31 PM
    08tacorunner
    08 Tacoma PreRunner
    I'm TRD Off-road he has a sport I did not know that. Yah I'm looking for tires anyways it's about time thanks for your help.
  14. Jan 12, 2018 at 1:29 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Unless it was different in ‘08, then OR and Sport share the same progressively wound coils, but varied valving of the bilsteins.
    Either way, you could probably put on a set of GEN 2 Sport Coilovers on and give it a go. Should be fairly inexpensive and I would place a wanted ad here first and check craigslist. I don’t recommend using GEN 3 setup because of the weight difference and will probably make your situation worse.
