Bouncy trd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CleanTRD, Feb 3, 2016.
  1. Feb 3, 2016 at 1:10 PM
    CleanTRD
    CleanTRD [OP] Well-Known Member
    Kareme
    2011 silver trd sport double cab
    4 inch lift,,5100 ride height shocks ,,3 inch block, 18 inch black wheels
    Hey guys I have bilsein 5100 ride height shocks in front and 3 inch block in rear ,, and my truck bounces a lot any remedies??
  2. Feb 3, 2016 at 1:12 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    New leafs and get rid of the block.
  3. Feb 3, 2016 at 1:13 PM
    CleanTRD
    Kareme
    Really blocks do that ?
  4. Feb 3, 2016 at 1:14 PM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    I see we're done here.
  5. Feb 3, 2016 at 1:16 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    And what height do you have the front 5100's at?
  6. Feb 3, 2016 at 1:16 PM
    07Speedway4X4
    07Speedway4X4 Active Member
    Seattle, WA
    2007 SWB AC 4WD TRD Sport
    Bilstein 5100's set at 2.5 w/ 1.5" block in rear ATX Mojave II 17x8 with Wrangler DuraTracs
    What are your 5100's set at and and are you using the factory springs or aftermarket? A block in the rear, while not the preferred method of users on this site, will maintain your factory ride and should not create the effect you are describing.
    doyouevenprerun likes this.
  7. Feb 3, 2016 at 1:16 PM
    CleanTRD
    Kareme
    5100s are set at 2nd setting
  8. Feb 3, 2016 at 1:17 PM
    CleanTRD
    Kareme
    Factory springs
  9. Feb 3, 2016 at 1:23 PM
    07Speedway4X4
    Seattle, WA
    With 5100's on the second setting with factory springs I'm not sure how you're getting a 4 inch lift as stated on your profile unless you are also running spacers, but I digress. With 5100's the higher the setting you have it on the more the factory spring is compressed creating a bouncier ride.
  10. Feb 3, 2016 at 1:45 PM
    CleanTRD
    Kareme
    That's what is so crazy I only have the 5100s on the second setting not even all the way up and I had to put a 3 inch block in the rear to level it out ... No spacers in the front just the shock I'm guessing around 4 inches because of the block
  11. Feb 3, 2016 at 1:46 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Take a picture of the front shock you might have the spring seat on upside down
    ChadsPride, Arailt and 07Speedway4X4 like this.
  12. Feb 3, 2016 at 1:56 PM
    07Speedway4X4
    Seattle, WA
    Just for comparison purposes I have my 5100's set on the highest setting with factory springs and I got just over 2.5 inches of lift.
  13. Feb 3, 2016 at 2:11 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Well that's not entirely accurate amigo, a block amplifies axle roll considerably which can easily add to an unstable or bouncy feeling in the ass end. Changing to an add a leaf or an add on tri-pack and ditching the blocks will make the back end feel much better.
    Arailt and Unchained 5150 like this.
  14. Feb 3, 2016 at 2:17 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    sounds like your front perches are upside down
    ChadsPride and Unchained 5150 like this.
  15. Feb 3, 2016 at 2:17 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    That's what I said
    bajatacoguy and T Fades[QUOTED] like this.
  16. Feb 3, 2016 at 2:26 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Post a photo that shows the collar the coil sits on, it is a very common mistake that people install that collar upside down and that adds too much lift.
  17. Feb 3, 2016 at 2:27 PM
    CleanTRD
    Kareme
    That could be a problem ,,, I was saying the truck lifted to much just from the shocks and I needed a three inch block ,, anyone have a pic of the proper installation I will have to check mine
  18. Feb 3, 2016 at 2:29 PM
    07Speedway4X4
    Seattle, WA
    I'm not running a 3" block so I can't comment 100% on his situation but I am running a 1.5" inch block and I experience none of what you are describing.
  19. Feb 3, 2016 at 2:32 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Ohh you've got axle roll buddy...you just don't know it and I won't give you any more details otherwise you will proceed down the rabbit hole of new leaf packs and shocks and and and ...and then your wife will blame me for the $2k you " need" to spend.
    Mount a GoPro under your truck someday aimed at your rear axle and go drive around a bit and watch the video...you'll be like this - :eek:
    TRDSmacker likes this.
  20. Feb 3, 2016 at 2:42 PM
    CleanTRD
    Kareme
    So I can't drive it like this it looks pretty badass and I just got it level..
