bout to change timing belt. what else should i do while i have that open?
Discussion in '1st Gen. Tacomas (1995-2004)' started by danielsan, Oct 15, 2012.
  1. Oct 15, 2012 at 10:50 AM
    danielsan
    danielsan [OP] Member
    daniel
    asheville nc
    95 4wd 2.7L
    hello
    i guess the title of this thread says it all.
    any tips are appreciated
  2. Oct 15, 2012 at 11:48 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    Replace the water pump, tensioner, and idler. And all the regular drive belts. Another bonus from buying a new tensioner is you won't have to buy a tool to compress the old one. It comes with a pin in it. Once all is in place, pull the pin and you're good to go. The last time I did this job I also replaced the upper/lower radiator hoses, front crankshaft seal, thermostat, and spark plugs at the same time. Once the radiator is out this is a surprisingly easy job.
  3. Oct 15, 2012 at 5:41 PM
    ExOkie
    ExOkie Well-Known Member
    Gary
    Denver Metro
    02 Red TRD
    Deckplate Mod, Airaid Intake Hose and Filter Kit, Leer 100R Camper Shell, WeatherTech floor mats, WeatherTech bug deflector, WeatherTech window deflectors, DesertDoesIt Seat Jackers.
    ^^^ X2
  4. Oct 16, 2012 at 6:38 AM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    Is this a good time to also inspect and replace the power steering pump and reservoir, if necessary?
  5. Oct 16, 2012 at 6:45 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    The 2.7L 4 bangers have chains not belts!
  6. Oct 17, 2012 at 12:36 PM
    danielsan
    daniel
    asheville nc
    95 4wd 2.7L
    timing chain. that changes alot. what are the maintenence specs on replacing timing chains?
  7. Oct 17, 2012 at 12:38 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Replace the chain guides too
  8. Oct 17, 2012 at 2:01 PM
    danielsan
    daniel
    asheville nc
    95 4wd 2.7L
    i'm getting some feedback saying timing chains don't necessarily need to be replaced and some are putting a replacement at 150k...
  9. Oct 17, 2012 at 2:07 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Yup. Timing chains last a long time. In most cases, its the guides that go first. So you might want to think about upgrading the guides to some better ones if they are original.
  10. Oct 17, 2012 at 2:34 PM
    chris66
    chris66 ( ͡°( ͡° ͜ʖ( ͡° ͜ʖ ͡°)ʖ ͡°) ͡°)
    dust
    CO
    2004 Prerunner
    bfg at ko2, method double standard
    thread jacking for a moment but i dont know if the last owner replaced the timing belt on my 04 v6. i tried to see if the lot that i bought it off of could get in touch with the old owner but the old owner seems to have gotten a new number.
    when do people normally do em? i dont want to blow the money if i dont have to.
    im currently around 135,000 miles. put 5000 on since i got it in january. the guy was the only owner and seemed to take care of the truck but i dont know what to do
  11. Oct 17, 2012 at 2:38 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    If it is original, I would replace it now.
  12. Oct 17, 2012 at 3:23 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    If a shop did it, they usually write the mileage by the radiator in paint marker. I think it's about 90k-100k miles.
  13. Oct 18, 2012 at 4:22 AM
    85GT 79FJ40
    Ken
    New Hampshire
    Well the good thing is it's a non-interference engine so if it snaps on you the truck won't run but at least you won't have damaged the engine. I believe the factory interval is every 90k miles. I didn't change the belt on our old 4 Runner until 146k though so you'll probably be fine. On my BMW if you don't change the belt every 5 yrs/50k miles they can and do break and it's ugly when it happens.
  14. Oct 18, 2012 at 1:58 PM
    danielsan
    daniel
    asheville nc
    95 4wd 2.7L
    thanks for all the help. is my 95 taco 2.7L 3RZ an interference or not?
  15. Oct 18, 2012 at 3:46 PM
    85GT 79FJ40
    Ken
    New Hampshire
    Most chain engines are interference designs. Chains do often stretch but typically the tensioner and guides make up for it and you usually can't tell. Unless you beat the tar out of your truck on a regular basis I wouldn't worry about it. Typically timing chains will get fairly noisy long before they let go.
