Bout to roll 100,000
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anders99, Nov 4, 2013.
  1. Nov 4, 2013 at 5:42 PM
    anders99
    anders99 [OP] The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    My 07 5 speed 4 banger is about to roll 100,000. I have read that there is no timing belt, instead it is a timing chain that is "lifetime". So since that doesnt need changing what should be done when she rolls the big 100?
  2. Nov 4, 2013 at 6:03 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    When it comes to the timing belt some people will change it out anyways. Just like the tranny flush. It's not in the maintenance because it's life time, people will do it on their own accord.
  3. Nov 4, 2013 at 6:38 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I changed all fluids. F/R diff, T-case, Trans, motor, coolant (with the stuff from the dealer) and greased everything. Also ran half a can of seafoam in the motor oil for a week before the oil change. I even swapped in a fresh set of Iridium plugs, but the ones that were in it were still ok, just gapped a little wide. Meh, drive it man.
    https://sites.google.com/site/tacomamaintenance/
  4. Nov 4, 2013 at 6:39 PM
    anders99
    Matthew
    Penscola, FL
    Thanks man. I was looking at doing an oil change since it will be due anyways and also front and rear diffs. Oh and the clutch will be being replaced because it is on the out and out. I don't know that the previous owner did but he was rough on it.
