Bow Hunting Advice
Discussion in 'Guns & Hunting' started by Bengland25, Apr 23, 2012.
  1. Jul 26, 2012 at 10:46 AM
    #381
    Bengland25
    Bengland25 [OP] Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
    Sounds good buddy, just shoot me a PM when your ready to go shooting!
    yeahhh in CA. depending on where I got its either a TON of trees or none at all... lol
    Sounds good buddy, I will be sending you a PM shortly!
    SIDE NOTE:
    Here are the requested photo's of me shooting, please tell me what you see I am I am doing right/wrong and what can be done to correct that! Looking forward to any and all input that I receive! I also have a range finder I used for construction that is suppose to be accurate up to the 1/64 at about 1000 yards. going to take that with me to the range when I sight the bow in for the rest of my pins.
  2. Jul 26, 2012 at 10:51 AM
    #382
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    Loosen your grip. Your feet aren't square with your shoulders
  3. Jul 26, 2012 at 11:03 AM
    #383
    nomad_archer
    nomad_archer Well-Known Member
    Trevor
    Brickerville (Lititz), PA
    08 DC Tacoma V6 SR5
    All right things look pretty good they only need slight tweeks here and there and you should be good to go.
    1. Try to get your front arm (bow) a little straighter and you will want to lower your elbow on your release hand. You may have to rotate your hand on the grip to make this possible. If you use your arrow as a reference in the pic the arrow and your shoulders should be very near parrallel. In this case your shoulders look pretty good and level but the arrow is not.
    2. Get your nose to touch the string! You want to have the tip of your nose touching the stirng this will give you a consistent anchor point. You may want to conisder getting a kisser button installed on the string so you will have two anchor points on the string. Your nose and the kisser button at the corner of your mouth.
    You will have to find the right place to anchor your hand. For me I use a thumb release and use my jaw bone between my index and pointer finger as my anchor point.
    3. Stand up straight. If you look at the pictures you are leaning ever so lightly backwards.
    The only other picture I could see being useful is one from directly behind your release elbow. That would allow me to see if you are leaning your head in or not. You dont want to lean your head into your bow. You want to bring the bow to you so your head and neck stay mostly straight.
  4. Jul 26, 2012 at 12:22 PM
    #384
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i think the form looks pretty good. i cant tell if the string is hard into your face. nomad has a great point..just tip your head a tiny bit and touch that string to your nose. but it may mess up your peep position.
    i like that bow!
  5. Jul 26, 2012 at 12:41 PM
    #385
    nomad_archer
    Trevor
    08 DC Tacoma V6 SR5
    if it messes up the peep position its time to move the peep. It will take awhile until your form gets consistent and repeatable. I typically move my peep at least once after it is initially tied in when I set up a new bow.
  6. Jul 26, 2012 at 12:49 PM
    #386
    Hubs
    Hubs Well-Known Member
    Agreed...with Muzzy...you can't go wrong! I use them with my Mission.
  7. Jul 26, 2012 at 1:23 PM
    #387
    aficianado
    back to bone stock.
    agreed! but i remember reading that the pro-shop glued his peep in. maybe the knots can still slide up and down a tad.
  8. Jul 26, 2012 at 4:31 PM
    #388
    PAlittlematty
    Beech Creek, PA
    I miss my taco
    Glued the peep in? Local shop here ties it in with dental floss
  9. Jul 26, 2012 at 8:52 PM
    #389
    TheGrinch
    TheGrinch Cheese Head.
    Sean
    RP, CA
    07 TRD DCSB OffRoad on 33's
    6" procomp lift
    Dental floss... Oh god...
  10. Jul 26, 2012 at 9:03 PM
    #390
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    I use power pro fishing lines #50lbs.= 12lbs dia. for tying my peep sight on works pretty well.
  11. Jul 26, 2012 at 9:03 PM
    #391
    PAlittlematty
    Beech Creek, PA
    I miss my taco
    Works very well. Tie it I and melt the end so it won't unravel. It's a no bullshit shop. And most of the work is done by 2 sisters
  12. Jul 26, 2012 at 10:55 PM
    #392
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    When I shot tonight I was trying to line up my feet to correct me slightly leaning one way or the other, seems to feel better and allows a better feeling shot as well.
    When shooting tonight I was rotating my grip and was only holding the bow with my thumb and palm when shooting. Felt great and assuming it straightened my arm as well. felt better IMO.
    In those pictures I did have my nose on the bow. also have the string against my "cheek" so I anchor in the same spot every time! loving the tips and I will try to get a picture from behind so you can criticize more! looking forward to it :)
    Thanks man! I LOVE my bow, it shoots amazing and I couldnt have been happier with my decision! I am trying to keep consistent with keeping my nose on the string! also trying to not tip my head at all while bringing the bow to my face and body.
    The peep actually seems to be just fine after the slight adjustments made. The only part that was glued was a small dab on the string that was used to tie it in.
    Thanks again everyone for the help and if there is anything else keep it coming! I am fletching my own arrows and shooting more and more! going to sight in the bow for 30,40,50,60 + this weekend! walked the new range I joined today and its gonna take up all my free time! looks amazing!
  13. Jul 27, 2012 at 4:31 AM
    #393
    nomad_archer
    Trevor
    08 DC Tacoma V6 SR5
    Dental floss and fishing line... well thats a new one by me. I've always had my peeps tied in with serving material which is the correct way to have them tied in. Anything else seems like a way for the shop to cut costs.
    OP- glad the form changes are working for you. Keep practicing and keep it fun. When it gets to serious its not fun anymore. I spent alot of time doing indoor 5 spot shoots and it was alot of fun in the winter but when I hit a wall and couldnt seem to improve my scores anymore I had to walk away for a bit because I forgot how to have fun shooting. If you get to a point where you dont feel like its fun and you arent improving take a break its much better then trying to fix things that arent broken. It took me years to loose the fun but just a warning. Archery is addictive. Im back at it again but I did loose the fun and needed to to take a few months off. Im back in the saddle again and its way more fun then I remembered.
  14. Jul 27, 2012 at 4:33 AM
    #394
    nomad_archer
    Trevor
    08 DC Tacoma V6 SR5
    OP- sounds like you have the grip right or very close. Good stuff
  15. Jul 27, 2012 at 4:58 AM
    #395
    REDTRD
    REDTRD Woods & Water Edition
    Anthony
    Western NC
    07 DCSB SR5 4x4
    Click my build thread!
    Form looks pretty good, elbow bent slightly, anchor point looks solid. I can't tell though are you shooting a thumb trigger release? I think you'll kill something for sure this fall!
  16. Jul 27, 2012 at 6:44 AM
    #396
    aficianado
    back to bone stock.
    i've used dental floss in the field as an emergency..it actually works GREAT..and you get that wiff of mint everytime at full draw. i know a shop that uses it too.
    me, personally i wouldnt. i like serving it in.. i cant do it the cool way, like they serving in the center-serving, but i am pretty decent with series of reversing square knots. (thanks youtube).
  17. Jul 27, 2012 at 9:04 AM
    #397
    nomad_archer
    Trevor
    08 DC Tacoma V6 SR5
    touche' there is more then one way to skin a cat but I will take the serving over dental floss.
  18. Jul 27, 2012 at 9:52 AM
    #398
    PAlittlematty
    Beech Creek, PA
    I miss my taco
    I'll get a picture of it tonight when I get home
  19. Jul 27, 2012 at 10:41 AM
    #399
    TheGrinch
    Sean
    RP, CA
    6" procomp lift
    exactly what it sound like to me. Why would a PRO SHOP use dental floss... Serving string isn't even that expensive.
  20. Jul 29, 2012 at 3:42 PM
    #400
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    I so far am loving it! thanks for all the help and as of now I cant see myself not having fun with it! my dad and I both enjoy it way too much and have spent around 4 hours yesterday and 4 hours today shooting. Have the bows sighted in up to 60 yards and shooting pretty decent groups as well! I feel like a little kid leaving Disneyland each time we leave, I just want to keep shooting all day! lol
    Fixed my grip a little more today! pretty much have my front hand there for support and not gripping much of anything. Rotated my elbow out and straightened my arm which made everything feel a heck of a lot better with the shot and follow through.
    Yes I am shooting a thumb release, when I ordered it, I never have shot one before and was skeptical at first with my decision. Cannot be happier though, love how consistent the anchor point is with it and allows me to pull a heavier weight with it as well..
