Box Rocket 1995 FZJ80 Build
Discussion in 'Other Builds' started by Box Rocket, Dec 8, 2014.
  1. Jul 25, 2018 at 9:29 AM
    #721
    Box Rocket
    Box Rocket [OP] Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    I have a floor jack and a couple sets of jack stands. You can get a decent floor jack at Harbor Freight for not much money.
    DoorDing likes this.
  2. Jul 25, 2018 at 9:34 AM
    #722
    duvinclunk
    duvinclunk Well-Known Member
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    Suppose I was asking if you needed a jack that would be able to lift quite high for your extreme droop...
  3. Jul 25, 2018 at 9:38 AM
    #723
    Box Rocket
    Adam
    Syracuse, Utah
    Nope, because your lifting the axles not the body. Jack up the axle and put a jackstand under each side.
    DoorDing and duvinclunk[QUOTED] like this.
  4. Jul 25, 2018 at 9:38 AM
    #724
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Use blocks of wood as a spacer on top of the jack
  5. Jul 25, 2018 at 9:43 AM
    #725
    duvinclunk
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    Ahhh duh, you're solid front axle too. I was thinking that was obvious for the rear but the front being independent would have made it a bit more difficult...but you're not independent front.
  6. Jul 25, 2018 at 9:55 AM
    #726
    Box Rocket
    Adam
    Syracuse, Utah
    With my Tacoma I did pretty much the same thing but it's not too terrible with the IFS since it doesn't droop that far.
    duvinclunk[QUOTED] likes this.
  7. Jul 25, 2018 at 10:13 AM
    #727
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    I just got my truck (+2 long travel) off the ground over the weekend with a 3-ton harbor freight floor jack and 6-ton stands
  8. Jul 26, 2018 at 9:14 AM
    #728
    Box Rocket
    Adam
    Syracuse, Utah
    Forgot to share a few recent mods here. First was upgrading the stock rear swaybar to the HD 11mm Blackhawk swaybar. This is the recommended swaybar for the Slinky Long Travel suspension. Doesn't limit rear suspension flex but really stabilizes the rear of the truck and improves corner turn in, especially in the dirt. This reduces understeer and makes driving fast in the dirt a much better experience as the truck will actually turn where you point it much better than with the stock rear swaybar.
    [​IMG]IMG_3841 by Adam Tolman, on Flickr
    [​IMG]IMG_3851 by Adam Tolman, on Flickr
    [​IMG]IMG_3849 by Adam Tolman, on Flickr
    [​IMG]IMG_3848 by Adam Tolman, on Flickr
    The other recent mod is happening in a couple stages. I'm working on reducing underhood temps. My coolant temps are fine for the most part but with the extra warm weather we've been having I'm seeing the coolant temps creep up just a bit. The ambient temps inside the engine bay are really warm and I'm sure it affects the coolant temps but also the intake temps, even with the snorkel. So in an effort to reduce the ambient engine bay temps the first stage was to add a hood scoop to bring more fresh air into the engine bay. The second stage (that I'm working on now) is to add two hood vents to the outside parts of the hood to let the heat out. The thinking is that the scoop will increase air pressure under the hood and the vents give it a place to escape and increase airflow in the engine bay and hopefully reduce the temps dramatically.
    I've completed the scoop portion using a modified late model mustang scoop. I looked at different Toyota scoops but the Tacoma/4Runner scoops just didn't have the right proportions for the Cruiser IMO. This scoop was the closest size for what I envisioned. There's a small rubber seal lip around the hood openings that will stop any water from just running across the hood and down the holes. So far the scoop on it's own is helping to lower temps so I think the addition of the vents will help even more.
    [​IMG]IMG_3961 by Adam Tolman, on Flickr
    [​IMG]IMG_3957 by Adam Tolman, on Flickr
    [​IMG]IMG_3975 by Adam Tolman, on Flickr
    [​IMG]IMG_3974 by Adam Tolman, on Flickr
    [​IMG]IMG_3960 by Adam Tolman, on Flickr
    [​IMG]IMG_3969 by Adam Tolman, on Flickr
    [​IMG]IMG_3971 by Adam Tolman, on Flickr
    [​IMG]IMG_3973 by Adam Tolman, on Flickr
    [​IMG]IMG_4020 by Adam Tolman, on Flickr
    [​IMG]IMG_4001 by Adam Tolman, on Flickr
    [​IMG]IMG_3999 by Adam Tolman, on Flickr
  9. Jul 26, 2018 at 9:20 AM
    #729
    duvinclunk
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    Is that a protective cover on your light bar?
  10. Jul 26, 2018 at 9:27 AM
    #730
    Box Rocket
    Adam
    Syracuse, Utah
    yes
  11. Jul 26, 2018 at 9:27 AM
    #731
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    How I’d the scoop secured to the hood? What material is it made out of? Steel, fiberglass?
  12. Jul 26, 2018 at 9:29 AM
    #732
    Box Rocket
    Adam
    Syracuse, Utah
    The scoop is a thick polymer. Very rigid and strong. It is attached using 3M trim tape. I could pick up the hood by the scoop when I had the hood off.
    DoorDing and boostedka[QUOTED] like this.
  13. Jul 26, 2018 at 9:29 AM
    #733
    duvinclunk
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    I like that! I had considered before how I might cover my bar when not needed (98% of the time). I had considered just loosening the hardware and tucking it behind the wind defector when not needed and then move/tighten it into place if needed.
  14. Jul 26, 2018 at 9:37 AM
    #734
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    What kind of temperature reduction did you get? Doesn't seem like much air would actually get into the scoop. Looks nice though.
  15. Jul 26, 2018 at 9:59 AM
    #735
    Box Rocket
    Adam
    Syracuse, Utah
    I was seeing temps between 199-210* during the hottest part of the day when climbing up Parley's Canyon. Hottest it's been since the scoop is 195* and 99% of the time its 190* or below.
    That's coolant temps. I haven't put a temp gun on the ambient temps yet.
    Glueman[QUOTED] likes this.
  16. Jul 26, 2018 at 10:52 AM
    #736
    boostedka
    James
    NM
    Thanks. I really like that idea
    :thumbsup:
  17. Jul 26, 2018 at 10:58 AM
    #737
    boostedka
    James
    NM
    Do you have any close up pics of how the scoop is sitting on the hood?
  18. Jul 26, 2018 at 3:07 PM
    #738
    Box Rocket
    Adam
    Syracuse, Utah
    Not sure what you mean.
  19. Jul 26, 2018 at 3:26 PM
    #739
    Glueman
    Utah
    The Plague....
    That's a decent drop! I'm running between 190 - 195 (up Parleys). It been pretty hot in SLC lately!
  20. Jul 26, 2018 at 5:42 PM
    #740
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Grand Cherokee guys steal the hood vents from the 5.9 ZJ's.
    The airflow over the hood creates a low pressure area, which sucks the heat out from under the hood. Combined with the engine fan, and air from under the rig, it works very well for keeping under hood temps down. From what i understand, you will see a larger jump in cooling effect from these types of vents once you do them, than you did from the hood scoop.
