Box Rocket Fab Bed Racks
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Box Rocket, Dec 5, 2012.
  1. Mar 19, 2013 at 7:11 PM
    #221
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Yeah, I saw that. I'm not worried about somebody removing the multiple bolts to remove the whole bed rack. I'll use the idea for locking the HiLift. I was just wondering if anybody had a way of locking the shovel and axe.
  2. Mar 19, 2013 at 7:24 PM
    #222
    Box Rocket
    Box Rocket [OP] Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    The standard size rack should fit behind your toolbox. I can probably add a CO2 tank mount. Just a matter of getting the mount ahead of time to make it fit right. You could use the same mount that I use for my tank. I could pick one up locally and you'd just have to pay the cost of the bracket.
    The clamps for the tools can be ordered with locking knobs for an extra $15ea
  3. Mar 19, 2013 at 7:27 PM
    #223
    Box Rocket
    Adam
    Syracuse, Utah
    Kinda hard to see but the knobs on this one have locks. You can sorta see the key slots.
  4. Mar 19, 2013 at 7:32 PM
    #224
    PcBuilder14
    Brent
    Nor Cal
    Hmm, awesome... Now I'm tempted to order one of these before rock sliders instead! Haha
    Do you think one of those tank mounts could fit sideways between the wheel wells and the bed rails? I want to keep everything out of the way as much as possible.
  5. Mar 19, 2013 at 7:36 PM
    #225
    Box Rocket
    Adam
    Syracuse, Utah
    Not sure what you mean. Do you want to lay it down on top of the wheel well?
  6. Mar 19, 2013 at 7:37 PM
    #226
    PcBuilder14
    Brent
    Nor Cal
    Yeah, pretty much. That way it's out of the way of the main bed-space.
  7. Mar 19, 2013 at 7:38 PM
    #227
    Box Rocket
    Adam
    Syracuse, Utah
    figure out where you want to put the tank. If the tank fits the bracket will fit.
    I guess you need to consider the opening of the locking arms. You'll need it in a spot that there is room for the arms to open.
    Here's mine again on my bed deck. It's pretty tight here to open the arms against the side of the bed.
  8. Mar 19, 2013 at 7:40 PM
    #228
    PcBuilder14
    Brent
    Nor Cal
    Hmm, I like that mount in the second pic. Would you be willing to make one of those? I'm thinking with that I can just set it in the back of my truck when trail riding, then just set it inside my truck so nobody steals it.
  9. Mar 19, 2013 at 7:49 PM
    #229
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Keep in mind that running co2 laying down is not recommended. They are only supposed to be used strait up or 45* and up.
  10. Mar 19, 2013 at 7:51 PM
    #230
    PcBuilder14
    Brent
    Nor Cal
    Hmm, dang. I want a way to be able to have it mounted in the bed when I need it, but be able to store it inside my truck to keep bed space open. I'd prefer not to drill holes in the bed just for a tank that will only be there when trail riding.
  11. Mar 19, 2013 at 7:58 PM
    #231
    Box Rocket
    Adam
    Syracuse, Utah
    I did not build that tank bracket. I got it at a local Fire Extinguisher supply shop. I have two of them (since I have two tanks) and they work great. Its the same bracket in the photo with my yellow tank. Monte is right that you should have the tank vertical when using it.
    Also, I would not just set that bracket in the bed of the truck and expect it to stay put on trail rides. It should be bolted down. A CO2 tank rolling around loose in the bed or inside the cab of the truck probably isn't the best idea.
  12. Mar 19, 2013 at 8:01 PM
    #232
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    anyone have these installed on a 2nd gen yet? Think I may go with this for my bed rack for my RTT
  13. Mar 19, 2013 at 8:07 PM
    #233
    PcBuilder14
    Brent
    Nor Cal
    I was thinking that maybe the tank bracket like something you had would keep it from moving around very much.
    I found this, I think I'll use these so it's minimal space used.
    Now it's just a matter of deciding whether to get one of these bed racks or sliders.... :confused:Haha
  14. Mar 19, 2013 at 8:08 PM
    #234
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    what will benefit you more is the only question you should ask.
  15. Mar 19, 2013 at 8:10 PM
    #235
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    I believe my order was his first bed rack for a 2nd gen. I also plan on mounting my RTT on it. He is backed up on orders, and I believe I won't be seeing mine until June sometime. So to answer your question, no one has this rack on a 2nd gen yet.
  16. Mar 19, 2013 at 8:17 PM
    #236
    PcBuilder14
    Brent
    Nor Cal
    Well if I get the bed rack, I'll buy all the recovery gear that I need to get so I can utilize the rack.
    But if I buy sliders it'll protect me from the many door dings I've been getting. Plus they look awesome haha I'm not sure how much I'll utilize the sliders, it all depends on how much trail riding I do while I'm in New Mexico...
  17. Mar 19, 2013 at 8:20 PM
    #237
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well you can mount it horizontal on the bed rack. But you'll just have to take it off to use it.
  18. Mar 19, 2013 at 8:22 PM
    #238
    PcBuilder14
    Brent
    Nor Cal
    I'll just use the mounts above and bolt them to the side of the bed. Mounting it to the bed rack and having to remove it every time I want to use it would get annoying.
  19. Mar 19, 2013 at 8:27 PM
    #239
    Blackdawg
    Monte
    Wyoming/St. Louis
    Good luck. The sides if the bed are further in then the bed rail..tank wouldn't line up. Also not sure how big those are..and if they would even work
    I have the same bracket as Adam. It works great..I see nothing wrong with drilling the bed if your okay with doing the sides.
  20. Mar 19, 2013 at 8:28 PM
    #240
    PcBuilder14
    Brent
    Nor Cal
    If I drill into the bed, then the mounts will have the tank laying sideways...
