BP-51 settings?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kauhi, Apr 6, 2017.
  1. Apr 6, 2017 at 9:53 AM
    Kauhi
    Kauhi [OP] Well-Known Member
    Kauhi
    From Maui, Live in Portland OR
    2016 Tacoma 4x4 Off Road
    285/75/16 KO2, OME BP-51 3" Lift Kit, TRD Exhaust, TRD CAI, 30" Light Bar Grille, etc...
    With peoplw that have OME BP-51 what are the current setting you have the coilovers set at
  2. Apr 6, 2017 at 10:05 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Would like to know as well. Mos tI have seen run factory.
  3. Apr 6, 2017 at 10:15 AM
    Cold_Toad
    Cold_Toad Well-Known Member
  4. Apr 6, 2017 at 11:15 PM
    WILDPEAK
    WILDPEAK Well-Known Member
    Drew
    Rancho Cucamonga, CA
    '16 TRD OFF-ROAD
    LT265/75R16 WILDPEAK AT3W
    Based on my experience with the factory setting, I helped another friend to an install and we set his at 10mm instead of the factory 20mm, he still yielded 3.5" on the front (no weight). I would recommend lowering it down from the factory 20mm to no more than the 10mm range unless you plan to have some serious weight on the front (bumper/winch).
