Bpf grille. Getting very hot
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yota31, Aug 17, 2019.
  1. Aug 17, 2019 at 10:05 PM
    Yota31
    Yota31 [OP] Well-Known Member
    Shannon
    Lifted 2006 Trd Sport Tacoma
    Led Tailights, OEM roofrack, 3 inch lift, Halo light bar and Black Wheels
    So I just installed my new bpf grille and when I driver for 30+ minutes around town. The grille will get so hot from my radiator I can actually smell it burning the 3m tape holding on the letters. Is it normal?
  2. Aug 17, 2019 at 10:13 PM
    MPA2point0
    MPA2point0 Well-Known Member
    Evan
    Havertown, PA
    2015 Super White DCLB Trd Sport
  3. Aug 17, 2019 at 10:46 PM
    Yota31
    Shannon
    I mean it's very hot. Any ideas? Mabye need a new radiator?
  4. Aug 18, 2019 at 2:03 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    The grill is about 1 foot away from the radiator with the AC condenser in between so what else do you have mounted on that grill like LED resistors? If in a hot state with the sun hitting the grill it can get hot but ………. Do you have a trans cooler mounted near it? What temp is it at (harbor freight has infrared gun probe cheap)?
  5. Aug 18, 2019 at 2:06 AM
    Yota31
    Shannon
    It's all stock if that helps. The grill does have Amber leds but the heat isn't from that. And it's not sun hot. It's like almost burn to the touch hot. Will look at it tomorrow. Was told it could be my thermostat. But I think that would make the engine hot not the radiator and my engine temp is normal
  6. Aug 18, 2019 at 2:23 AM
    muddog321
    FL
    I would disconnect the LEDs and see if some short to ground was heating the grill. Radiator and engine run about 190 but not physically attached to the grill. Grill just drops into the bumper and attaches at top by headlight frame mounts so something else must be the cause.
    VanDoom and THE_KiRRAx like this.
  7. Aug 18, 2019 at 2:35 AM
    Yota31
    Shannon
    Okay. Will check that out in the morning
  8. Aug 18, 2019 at 6:01 PM
    Yota31
    Shannon
    Update. It's not getting as hot as it was before. And I believe it's getting hot from my radiator. I don't think air flows through the grill as well making it get hot between the radiator and grille
  9. Aug 18, 2019 at 7:06 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Your fan is pulling air towards the engine - I doubt it's the radiator.
  10. Aug 18, 2019 at 7:30 PM
    Yota31
    Shannon
    When I stick my hand behind the grill I can feel the heat from the radiator
  11. Aug 18, 2019 at 7:59 PM
    Fullboogie
    Dave
    Houston
    You certainly should not feel the heat you're talking about. You sure your fan clutch is working?
  12. Aug 18, 2019 at 8:58 PM
    Yota31
    Shannon
    Should I take my truck to Toyota to look at it. I know nothing about engine stuff. Just exterior stuff
  13. Aug 19, 2019 at 3:03 AM
    muddog321
    FL
    Dealer hates to look at anything modified just saying.
    With engine OFF, Fan clutch when cold turns freely and should not have a lot of play when you wiggle/rock it around and no fluid leakage.
    After warmup, then again with engine OFF, Fan clutch have some resistance when spinning so if it still spins freely time to replace.
    But if it worked OK before the new grill doubt that is it. Did you move or remove the fan shroud? Do you have the tow package so there is a trans cooler on drivers side that may be contacting the new grill. Did you add a new skid plate that blocks the intake from the front below the grill (look down and see or get under and look up its a good 6-10" gap.
    Out of ideas now. Going fishing now for the day so hope you find the cause.
  14. Aug 19, 2019 at 5:01 AM
    Yota31
    Shannon
    Will check all this out after I get the truck back from getting window tint. The truck has a body armour front bumper and also has the tow package
  15. Aug 19, 2019 at 5:35 AM
    Yota31
    Shannon
    So the fan does spin freely when the truck is off. No resistance
  16. Aug 19, 2019 at 1:35 PM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    Is your coolant low? Does is spew out anywhere? If the heat your describing is really that hot then your truck should be over heating.
  17. Aug 19, 2019 at 4:39 PM
    Yota31
    Shannon
    No it isn't overheating. I do pull a trailer loaded down 3 days a week and always stays normal. But I have noticed my coolant is slowly disappearing. Very slowly. Mabye a very small leak. Never see anything wet though
