Bpf skid and tow hook question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dmwood1984, Jan 29, 2018.
  1. Jan 29, 2018 at 5:37 AM
    Dmwood1984
    Dmwood1984 [OP] Well-Known Member
    New Jersey
    2018 Cement TRD Off-Road Double Cab Long Bed Premium Package with Options
    im thinking about jumping into that group buy -but have a couple questions- I have a 2018 off-road so it seems:
    I’ll need new hardware for the hd recovery hook correct?
    I’ll need to use soft shackles vs the standard metal ones correct?
    Does anyone make drivers side recovery hooks to match or does everyone typically just run the passenger side?
  2. Jan 29, 2018 at 6:33 AM
    Istan
    Istan Leave it stock they said
    Stan
    Vegas and Yuma
    03 Xtra Cab 5Speed 4*4
    I had to get hardware for my bpf hook. I cant remember the exact soze but if no one chimes in later ill try to find it. I did a search to find the correct size.
    I use a soft shackle on the bpf tow hook.
    The drivers side is a different hook I believe used for tie down if you are being towed. It doesn't have the same mounting so unless you have something fabbed, I would leave it be.
  3. Apr 2, 2018 at 7:20 AM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    M12x1.25x40mm Bolts grade 8 or higher.
