BPV adjustment arm
Discussion in '1st Gen. Tacomas (1995-2004)' started by Space Wrangler, Apr 19, 2010.
  1. Apr 19, 2010 at 7:42 AM
    Space Wrangler
    Space Wrangler [OP] Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    i recently lowered the rear of my truck about 1" by removing my coil helper springs. ...now i can't remember if i need to adjust the bpv arm by moving it higher or lowering it.
    if i recall, as the arm is moved up, it adds more rear brakes. ...if you move the arm down, it adds more front brakes.
    can someone confirm this? ...or is my thinking bass akwards?
  2. Apr 19, 2010 at 8:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Your thinking is correct. You would want to drop it a little bit.
  3. Apr 19, 2010 at 9:41 AM
    Space Wrangler
    JCT
    Ga
    04 DC 4x4
    thank you, sir.
