Brake Bleed / Changing Brake Fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco John, Apr 11, 2011.
  1. Apr 11, 2011 at 1:42 PM
    Taco John
    Taco John [OP] Well-Known Member
    Illinois
    4X4
    Anyone done this on a gen 2? It looks straightforward, but I don't like gotchas. I'm going with the old 2 person pump the pedal mode.
    kidthatsirish and Rambo54 like this.
  2. Apr 11, 2011 at 1:53 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I don't think it's any different than any other vehicle.
    That's on my to-do list for the taco. My fluid is getting a little dark.
    Rambo54 likes this.
  3. Apr 11, 2011 at 1:56 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    Did it a few weeks ago. Just worked from furthest to closest and that was about it.
    Nothing to it.
  4. Apr 11, 2011 at 2:47 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Piece of cake on almost any vehicle. I do remove each wheel to get a better view of the bleed valve. I did my 4Runner last month and actually found that the place that did my master cylinder let air in the line. No more squishy brakes now.
    Just have a helper press on the brakes as you open the valve. When they say 'bottom' lightly close the valve and let pedal go back up. About every 10 "pumps" check the fluid level in the brake reservoir and add more clean fluid.
    I do wish there was a dye you could add to your bottle of DOT 3 so you can tell if you've flushed it all out. If there is I would be interested to know where I can purchase some.
    a400ryan and Rambo54 like this.
  5. Apr 11, 2011 at 5:06 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    ATE makes some DOT 4 brake fluid in at least two colors, blue and amber. The blue is called "Super Blue" and the amber is called TYP 200. They have the same specs, just different colors.
    http://www.raceshopper.com/ate_brake_fluid.shtml
  6. Apr 11, 2011 at 5:08 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    I've read somewhere on this forum that bleeding the newer models with brake boosters/ABS can cause severe brake problems. I know even chris4X4 was concerned about this.
    Anybody can add something to that???
    Jon G likes this.
  7. Apr 11, 2011 at 5:24 PM
    accesscab
    accesscab Well-Known Member
    Do not turn the key on when you do it, and when your done, pump the pedal until its real firm before you turn the key on.
  8. Apr 12, 2011 at 6:07 AM
    Taco John
    Illinois
    4X4
    I had already started the job last night before I saw this. The ABS added a bit of complexity, but I had run into a twist with the ABS on my wife's car. The solution wasn't the same for both cars, but it at least sent me down the right path.
    I can't tell you how Toyota recommends doing the job, but I can tell you about what I did and I believe it was successful. The first time I opened the bleeder valve on the right rear, fluid came out normally but my wife noted that the pedal did not sink. I tried it again and the pressure on the fluid started to drop. I closed everything up, looked around and all was normal so I had her turn the key on to cycle the ABS pump. After several attempts I figured out this process:
    I had her turn the key on but not start the truck. I would have her press and hold the pedal. Once I opened the bleeder, the pump would start and maintain pressure as the fluid flowed. The pedal would not sink. Pretty soon it had pushed through most of the old fluid and I topped it with new and went back in for another round until I saw the new fluid come out at the rear (the new fluid was slightly more clear).
    I did the same on the left rear but instead of draining the entire reservoir, I only ran until the new fluid came through.
    The fronts bled normally.
    Pedal is firm and the fluid is new and I got an opprtunity to try out a panic stop on the way into work today thanks to someone not paying attention :)
    Also, I will chime in on the colored fluid as I have done some research from another vehicle. ATE does make the blue and amber dot 4 but it is expensive and hard to find so online ordering is the only option that I know of for most. If you have a race shop nearby, they may be able to get it for you. The blue is really designed for people who change their fluid regularly (racers and such) as normal brake fluid darkens with moisture contamination and is an indicator of a problem/ old fluid. With the blue dye, you lose that feature. Also, I have heard that running the blue on the street is illegal in Florida (I have not confirmed) probably for the contamination reason so if you are concerned, you may want to check local law.
    Taco 422 and EPH like this.
  9. Apr 12, 2011 at 7:02 AM
    Taco John
    Illinois
    4X4
    Nice addition. That is basically the procedure I used but their write up is nicer and includes more complex situations. I am glad that it is Toyota approved. I wish I would remember that site is out there!
  10. Apr 12, 2011 at 10:14 AM
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    And what about the ABS syst? leave it alone? I've done this job before but with all the electronic crap on these vehicles...Whacha say?:confused:
  11. Apr 12, 2011 at 10:16 AM
    romafern
    Rob
    80918 Let's meet!
    never mind....found the answer above.
  12. Apr 12, 2011 at 10:26 AM
    romafern
    Rob
    80918 Let's meet!
    READ post 13 LOL:D:D:D:D:D
  13. Apr 12, 2011 at 10:45 AM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    ATE Super Blue is a performance brake fluid...If you like bleeding your brakes great then use this stuff...bc it only last 6 or so months and tben you will have a spongey pedal...otherwise what the owners manual calls for is perfectly fine for most people
  14. Oct 27, 2011 at 10:39 AM
    04SilverTRD
    04SilverTRD Member
    Wisconsin
    04 Access cab 4x4 Silver - Stock
    None
    Why do you say that? What is your evidence? The fluid is design to last 3 years, so your 6 month estimate is hard to believe. Also, I've never heard of a spongy pedal being blamed on bad fluid. Sounds like you have a leak allowing air in the system, not a fluid issue.
    Plenty of people use it just fine.
    Stryker420 likes this.
  15. Nov 18, 2011 at 8:53 AM
    RecklessTaco
    RecklessTaco Livin the Dream
    Topaz Lake, Nv.
    08 Dbl Cab Prerunner TRD Sport Debadged
    ENGAGE LT KIT, King 2.5x 8" coilovers w/600lb 18"coil springs, a custom built leaf pack in the rear by OMD, and a custom built prerunner bumper by SurfInferno. 35x12.50-17General Grabbers on 17x9 Black MB Wheels rims, Volant CAI w/Amsoil dry filter, Volant Ram Air, Poweraid Throttle body spacer, URD MAF Calibrator, Flowmaster40, Uniden Bearcat cb w/ 4' fire fly firestick antenna, & a Icom V80 Handheld(Modded for race channels)
    What size wrench did you use for the bleeder valves? Wanna make sure i have the right one to do the job.
  16. Jun 19, 2017 at 10:36 AM
    doughpat
    doughpat Nerd With a Sweet Truck
    Bend, OR
    2006 TRD Sport, DCLB
    Dredging up this thread....anyone happen to know the size of wrench used for brake fluid plug/valve-thing?
  17. Jun 19, 2017 at 10:51 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I used a 10mm wrench for the bleeders IIRC.
    Rambo54 and doughpat[QUOTED] like this.
  18. Jun 19, 2017 at 4:34 PM
    Rambo54
    Rambo54 TacomaBob
    Robert
    Eustis,FL
    2013 Nautical Blue Metalic Tacoma PreRunner DCLB
    Many !
    How many pints of Brake fluid for a FULL FLUSH ???? A real good FLUSH !
  19. Jun 19, 2017 at 5:21 PM
    Incognito
    VA
    A 1-1.5 liters will get you a real good flush. I used a liter FWIW.
  20. Oct 9, 2018 at 2:49 PM
    BLACKFIREPDX
    BLACKFIREPDX BlackFire PDX
    2015 TACOMA DBL CAB
    Front BP-51 and rear Firestone airbags
    Are there any manual brake pressure bleeders out there for 2015 Tacoma's? I thought i read the difficult is the cap isn't the same as a domestic or German. Seems less mess than vacuum bleeder.
