Brake bleed time
Discussion in '2nd Gen. Tacomas (2005-2015)' started by igno1tus, May 14, 2023.
  1. May 17, 2023 at 10:05 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Is that with DOT 3 or DOT 4 fluid?
  2. May 17, 2023 at 12:19 PM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    I just use DOT 3 (not that I couldn't use DOT4). From what i have read DOT4 just has the advantage of higher wet/dry boiling point..
    https://www.autozone.com/diy/brakes/dot-3-vs-dot-4-brake-fluid
    After reading this its appear that DOT4 actually absorbs water faster than DOT4 so needs to be changed more often... Didnt know that but if you do a change at least every 3 years it probably doesn't matter.
    DOT 3 fluid typically includes 80% glycol ether base which is one of the factors that contribute to water absorption.
    DOT 4 fluid typically has 50 to 65% glycol ether base with 20-30 % Borate Ester and as a result the DOT 4 fluid will absorb 20% faster than a DOT 3 Fluid.
    Rob MacRuger likes this.
  3. May 18, 2023 at 10:07 AM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Why not use DOT 5.1?
  4. May 18, 2023 at 11:35 AM
    TacoTuesday1
    FL
    because it costs twice as much and is for race bikes
