Brake bleeding help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DarthPow, Sep 7, 2019.
  1. Sep 7, 2019 at 1:36 PM
    DarthPow
    DarthPow [OP] Well-Known Member
    2012 DCLB TRD Sport 4x4
    So I'm trying to bleed/flush my brakes. They bleed fine from the calipers, and I get fluid from all 4. I'm starting from the passenger rear, then driver rear, then passenger front, and finally driver front.
    When I bleed with the truck off, the pressure builds on the pedal, until I get a firm pedal. Once I'm done bleeding all 4 wheels, I turn the engine on, and then the pressure in the brake pedal seems to get lost, and it just goes to the floor.
    Not sure what to do at this point.
    I'm thinking maybe something is going on with the master cylinder, maybe air got all the way up there.
    Any help would be appreciated.
  2. Sep 7, 2019 at 1:49 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Stupid question, but are you refilling the brake reservoir in between each brake the you bleed?
  3. Sep 7, 2019 at 1:49 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Maybe bleed it running?
    Are you doing gravity or a two person pump the pedal?
    wilcam47 likes this.
  4. Sep 7, 2019 at 1:50 PM
    DarthPow
    Not between each brake, but I am checking the reservoir, and making sure it never gets below the "min" line on it
    Drainbung likes this.
  5. Sep 7, 2019 at 1:51 PM
    DarthPow
    Two person procedure. I'm having him pump the pedal 3 times, then hold it down, while I open the valve, let it run for a few seconds, then close the valve, and have him release the pedal.
  6. Sep 7, 2019 at 1:53 PM
    DarthPow
    I haven't tried bleeding it with the engine running, because most of the instructions on it say to do it with the engine off.
  7. Sep 7, 2019 at 1:54 PM
    crashngiggles
    Jared
    Are you doing it by yourself or with another person?
    The order you have is correct.
    Passenger rear: crack the bleeder, press and hold brake, close the bleeder, release brake. Do this until all air bubbles are out. Fill master cylinder to max line.
    Repeat process for driverside rear.
    Repeat process for passenger front.
    Repeat process for driverside front.
    Marc70 likes this.
  8. Sep 7, 2019 at 1:54 PM
    crashngiggles
    Jared
    Engine off.....not on. You have the sport, not the offroad.
    Marc70 and DarthPow[OP] like this.
  9. Sep 7, 2019 at 1:57 PM
    DarthPow
    Yes I have a sport. But it's weird that it loses pedal firmness once the engine is turned on.
    That's what's making me wonder if there's a problem in the master cylinder or with the vacuum pump or something along those lines.
  10. Sep 7, 2019 at 2:01 PM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    Turn in on and repeat your bleeding procedure. I always bleed my sport running with 1 person pumping and holding. Never a prob. With no power you will loose pressure just like what’s happening.
  11. Sep 7, 2019 at 2:03 PM
    DarthPow
    Is there any chance that bleeding it while it with the engine is running would cause any problems or damage?
  12. Sep 7, 2019 at 2:05 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    you are about right, I just dont count the pedal pushes. I have the person inside pump the brakes till its hard to push the pedal, have the person press one final time at the same time open the bleeder, then let it run a split second (should be a steady stream no bubbles) then close it off. repeat for each. Dont do it with the truck running.
    Jeffch and crashngiggles like this.
  13. Sep 7, 2019 at 2:05 PM
    crashngiggles
    Jared
    You can do it with the engine off but with the key in the on position. Have you been doing this?
  14. Sep 7, 2019 at 2:07 PM
    DarthPow
    Yes, that's how I've been doing it. Key in the On/ACC position, but engine off.
  15. Sep 7, 2019 at 2:09 PM
    crashngiggles
    Jared
    Another stupid question.....but you are using brand new brake fluid correct?
  16. Sep 7, 2019 at 2:10 PM
    DarthPow
    Yes
  17. Sep 7, 2019 at 2:10 PM
    DarthPow
    If it helps, I'm getting much more fluid from the front brake than I am from the rears.
  18. Sep 7, 2019 at 2:11 PM
    crashngiggles
    Jared
    Then you might want to get it checked out, you may have some small foreign object stuck in the lines or maybe a master cylinder problem.....but both of these are somewhat unlikely.....
  19. Sep 7, 2019 at 2:13 PM
    DarthPow
    I wouldn't discount the possibility of issues with the master cylinder, especially if air got up there. My truck has been sitting in the driveway with the lines open for about a week.
  20. Sep 7, 2019 at 2:16 PM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    I bleed it running when I installed brake lines. Also did it on brake jobs and to flush the fluid
    DarthPow[QUOTED][OP] likes this.
