Brake bleeding question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ajw1986, Sep 16, 2013.
  1. Sep 16, 2013 at 10:39 AM
    ajw1986
    ajw1986 [OP] Well-Known Member
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    I replaced my front brakes and rotors yesterday, after the install we bled the front brakes and the pedal still had a bit of play. I drove home and realized it's not right so i just took it easy. I assume we have to bleed the backs as well? First brake replacement i've had to do on a toyota so i'm not sure
  2. Sep 16, 2013 at 10:41 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    YOU SHOULD NOT HAVE TO BLEED YOUR BRAKES FROM JUST REPLACING PADS AND ROTORS.....
    IF YOU REPLACED THE CALIPERS THEN YES
  3. Sep 16, 2013 at 11:00 AM
    ajw1986
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    Oh sorry, i forgot to mention i took the calipers off to paint them.. MY BAD:cool:
  4. Sep 16, 2013 at 11:03 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    If you pulled the calipers you most likely have air in the system now. Time for a full system bleed.
  5. Sep 16, 2013 at 11:09 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    OK THEN YES BLEED THEM
    START FROM THE FURTHEST POINT "REAR" THEN TO THE 2 FRONT ONES.....
    JUST MAKE SURE YOU KEEP AN EYE OUT OF THE FLUID LEVEL
    DO NOT LET IT DROP BELOW MIN...OR YOU WILL BE FLAT BEDDING IT TO A DEALERSHIP.......
  6. Sep 16, 2013 at 11:11 AM
    ajw1986
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    Figured, couldn't get the bleeders on the rear open last night with a crescent wrench so doing it now with a closed 10m. Thanks guys!
