Brake booster noise on cb
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cnstaco, Jul 22, 2018.
  1. Jul 22, 2018 at 5:59 PM
    cnstaco
    cnstaco [OP] Well-Known Member
    CO
    17 DCSB OR
    installed a cobra 75 in a 17 OR last weekend. Everything works great accept the horrible noise when I hit the brakes every so often. Yes it’s grounded and powered straight to the battery. I rerouted the wiring moved grounds no difference. I’ve narrowed it down to the power lines not the antenna. Has anyone figured out a solution yet or had this problem? I saw the fj’s we’re having a similar problem saw a couple of fixes they did but hate to mess with brake booster wiring.
  2. Jul 22, 2018 at 6:27 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
  3. Jul 22, 2018 at 8:38 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    try a ferrite choke. see if that helps.
  4. Jul 23, 2018 at 3:20 PM
    GulfCoastMike
    GulfCoastMike Co-pilot Angel
    Pascagoula, MS
    2017 MGM AC SR5 3.5L A/T
    It is common to have noise problems when you run a power wire all the way from a battery.
    That long wire acts like an antenna and will pick up any noise being produced under the hood.
    CB radios are AM and very prone to noise. Everything from the alternator to the wiper motors can generate noise.
    The best solution is to go to an electronics store and buy the largest electrolytic capacitor (in micro farads) you can. Make sure it is rated for 25 volts.
    Connect the positive side to the red wire as close as possible to the radio. Ground the negative side.
    Capacitors only allow AC (noise) to pass. This configuration will ground the noise, allowing pure DC to pass.
    One last note. Capacitors try to maintain a steady voltage in a circuit. Ferrite coils, as mentioned above, try to maintain a steady current. They should be mounted in series with the power wire and will do little to reduce noise.
    BillsSR5 likes this.
  5. Jul 23, 2018 at 4:31 PM
    M-cameron
    M-cameron Well-Known Member
    2017 Tacoma
    where do you have it mounted?
    i have mine mounted in my center console and just pull power right from the center console cigarette lighter.......no noise at all.
  6. Jul 28, 2018 at 6:11 PM
    cnstaco
    CO
    17 DCSB OR
    The antenna box is in the glove box. Did you wire a cigarette lighter adapter to it? I installed a kenwood rf choke today cut the noise to 50%. I may try a different filter that has a electrolytic capacitor as mentioned above. I’ll report back when I find what works best. Thanks for the responses.
  7. Aug 25, 2018 at 6:39 AM
    cnstaco
    CO
    17 DCSB OR
    Just an update. So if anyone has this issue the kenwood RF choke gets wired inline(red) as close to the antenna box as possible, you can cut the ground off and delete the clips as it won’t work with cobra 75 but make sure it’s in the right direction. Sorry no pics. I double checked that all my grounds were good. Tuned my antenna with an swr meter and now with the squelch adjusted properly and sound tracker on there is no noise. My range is short but I’m running a 2’ firestick so that’s a given.
