brake caliper question?????
Discussion in '1st Gen. Tacomas (1995-2004)' started by BoneStorm, Dec 4, 2010.
  1. Dec 4, 2010 at 1:54 PM
    BoneStorm
    BoneStorm [OP] New Member
    Jared
    Wilmington IL.
    03 Tacoma 4X4 TRD
    3" Coilovers ProComp Xteraines Cold Air intake
    Has anyone ever had the brake line bolt (the bolt that fluid actually flows through)on a front caliper work loose? This has happened to me twice now, causing a leak and pedal fade.:( Thoughts on what causes this and what I can do to prevent it from happening again.
    Thanks
  2. Dec 4, 2010 at 3:12 PM
    BoneStorm
    Jared
    Wilmington IL.
    03 Tacoma 4X4 TRD
    Anyone????
  3. Dec 4, 2010 at 3:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The "Banjo" bolt".....You may want to use some Blue Locktight on it.
