Brake Caliper Replacement-2006 Tacoma Sport
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danteisme, Sep 6, 2017.
  1. Sep 6, 2017 at 10:33 AM
    danteisme
    danteisme [OP] Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    My 2006 Sport Tacoma's front driver's side caliper is seized. Its all rusted up and i can tell it has the pads seized a bit, there is all kinds of heat coming off that side and when i brake the truck pulls to the passenger side. I got rebuilt calipers i want to install for both sides, and it seems like the bleeding procedure should be straight forward from what i read in the repair manual. My truck doesn't have vehicle stability control so it should be a standard bleeding procedure, correct?
    Any input would be appreciated, I don't wanna get half way through this and be stuck with no brakes.
  2. Sep 6, 2017 at 11:18 AM
    Muddinfun
    Muddinfun Well-Known Member
    Make sure you unbolt the bracket for the rigid line before you remove the caliper so you don't bend the hard line.
  3. Sep 6, 2017 at 11:20 AM
    danteisme
    South Western PA
    for sure, although it is so rusted up it will probably just break on me anyway.
  4. Sep 6, 2017 at 11:57 AM
    Muddinfun
    You can buy prebent hard lines from the dealer. Might be worth getting.
  5. Sep 7, 2017 at 7:21 AM
    danteisme
    South Western PA
    Good tip, i'll have to stop by the dealer and see how much they are.
  6. Sep 12, 2017 at 5:35 AM
    danteisme
    South Western PA
    that was a great idea, i ordered the 2 brake lines and i'll be picking them up today. $15 for both of them, that is worth it to me.
