Brake caliper tool and brake shims?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CenterKnurl, May 21, 2025 at 7:31 AM.
  1. May 21, 2025 at 7:31 AM
    CenterKnurl
    CenterKnurl [OP] Well-Known Member
    Going to change my front brake pads soon. Mechanically inclined but has free labor from a mechanic shop for a while where I could just take them OEM parts and they'd install them.
    1. Do I need to buy new shims when I replace just the pads? In some YouTube videos it looks like people aren't even using shims at all. I would always buy OEM shim kit from Toyota and take them to my mechanic. Here are the shims: https://autoparts.elmhursttoyota.co...omv2ARrilNgSqQHzZz8pDYIJhQqThoZ_PqsvNKsiIkd3F
    2. In some YouTube videos people are using caliper piston compressing tools. Are these necessary? Worth it for $25 to get the ratcheting piston compressing tool?
    Just changing pads this time - not the rotors.
  2. May 21, 2025 at 8:43 AM
    wayne0
    wayne0 Well-Known Member
    I just use a big C clamp.
  3. May 21, 2025 at 9:06 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    If the shims look good reuse them definitely don’t use OEM disc brake pads and not reinstall the shims. I don’t know about using aftermarket pads never used them.
  4. May 21, 2025 at 9:08 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I had a braking vibration at 40K miles on my factory brakes, so I went with PowerStop. Otherwise, I like to stay with OEM. I now have 20K miles on PowerStop and very happy with them. If you have not bought your pads yet, you might consider a front brake kit. PowerStop kit even comes with a packet of brake grease even though I had my own.
    C clamp should work fine compressing the caliper pistons. Just remove the cap on the brake fluid reservoir first.
    https://www.amazon.com/dp/B005FKS28C?ref=ppx_yo2ov_dt_b_fed_asin_title
    t0p_d0g likes this.
